Author Topic: I need a trans for my AAZ.  (Read 4683 times)
August 10, 2011, 12:22:55 pm
trent77
  • 217
« on: August 10, 2011, 12:22:55 pm »
I have a 5 speed. the code is CHD29092 . It came in a 1994 jetta Canadian. Hopefully someone has one near me. Help is appreciated. Thanks, I'm located in eastern Iowa now.
Trent
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1August 10, 2011, 05:28:25 pm
ilikevwdiesel
  • 1202
Re: I need a trans for my AAZ.
« Reply #1 on: August 10, 2011, 05:28:25 pm »
there are some parts cars listed on craigslist in IA. I used crazedlist to find them it's easier. what year/model is the engine in?
My Bio
Reply #2August 10, 2011, 05:42:24 pm
trent77
  • 217
« Reply #2 on: August 10, 2011, 05:42:24 pm »
It's in a 91 jetta. If I use a gasser trans, what is a good one? I've heard of people doing it.
77 westfalia
06 GMC Duramax
Reply #3August 10, 2011, 06:54:09 pm
ilikevwdiesel
  • 1202
« Reply #3 on: August 10, 2011, 06:54:09 pm »
any mk2 gasser trans will work, I'd try for a wide ratio unit myself, some folks like the close ratio gti/gli/scirocco/cabriolet boxes. the only hassle will be changing out drive flanges if the new trans isn't the same size that you have now. go to www.scirocco.org and click on the "gears" link. there's a good chart on there with codes and gear sets. you can use a mk3 2.0 gasser trans too but the clutch disk is different than the AAZ one so if you get a mk3 trans make sure to get the clutch disk too.
My Bio
Reply #4August 10, 2011, 07:07:36 pm
Quantum TD
  • 1195
« Reply #4 on: August 10, 2011, 07:07:36 pm »
Blown reverse??? ;D
Reply #5August 10, 2011, 07:17:16 pm
trent77
  • 217
« Reply #5 on: August 10, 2011, 07:17:16 pm »
No, reverse would probably work if I could get it  out of third!! I guess it is a relatively frequent problem. There is a write up on it on brokevw.com . Supposedly you cannot easily get it apart if it is stuck in gear, and I have tried everything to get it out of gear....A new trans is going to be the answer.
77 westfalia
06 GMC Duramax
Reply #6August 10, 2011, 07:50:50 pm
« Reply #6 on: August 10, 2011, 07:50:50 pm »
you gotta stick it in 2 gears to get it apart.. once shift selector is out.. then you can move 1or 2 to lock it in with 3rd to get the 5th gear bolt loose.. so i say wrong.. stuck in 3rd make it easy to get apart..
Reply #7August 11, 2011, 04:55:13 am
CdnVWJunkie
  • 309
« Reply #7 on: August 11, 2011, 04:55:13 am »
Check your PMs
Reply #8August 11, 2011, 06:58:06 am
trent77
  • 217
« Reply #8 on: August 11, 2011, 06:58:06 am »
But how do you get the selector out? I removed all of the circlips and it will not come out without having it between gears. Besides, my tranny feels "growly" when I rotate it, so I'm thinking the parts needed to get it back on the road will not be worth it. Thanks
77 westfalia
06 GMC Duramax
Reply #9August 11, 2011, 09:47:51 am
« Reply #9 on: August 11, 2011, 09:47:51 am »
there are lots of good mk2 gasser trannies.. ACN is my favorite.. there are plenty of other long ratio trannies out there tho.
gotta use a 22mm hub clutch tho. and im not sure if your engine has a 22, or 24mm clutch hub.
Reply #10August 11, 2011, 07:31:58 pm
trent77
  • 217
« Reply #10 on: August 11, 2011, 07:31:58 pm »
Well I was planning on changing the clutch and pressure plate anyway. As loong as I change it to match it should work, shouldn't it? I thought that any of the 020 could run either clutch as long as the pressure plate was changed.
77 westfalia
06 GMC Duramax
Reply #11August 12, 2011, 02:14:28 pm
« Reply #11 on: August 12, 2011, 02:14:28 pm »
no.. the pressure plate and flywheel are universal..
its the clutch that needs to match the trans..
if its a 2.0 8v trans, 16v trans, or AAZ trans, it should be a 24mm big input shaft..
if its anything else, it should be a 22mm small input shaft..
say you used an old mk2 8v gasser trans, you would also have to use a clutch that is compatable with the 22mm main shaft.. all mk2 8v gassers had 210mm clutches AFAIk..
