Author Topic: Mtdi mk1 rabbit Information wanted!!  (Read 2117 times)
July 26, 2011, 02:48:25 pm
BigVWman
  • 332
« on: July 26, 2011, 02:48:25 pm »
It seems i have scored another deal on an ahu longblock plus some accesories(needs some refreshing but no pump). I already have a fully electronic 1z in a mk1 and am mid process of a ahu in mk3 cabrio but now i want to see how the other side lives- MTdi. Simple and sweet. I need some good suggestions on pump and turbo as well as turbo control? I see most going land rover pump with slight mods, is that the next best thing to a giles special? On the turbo i was thinking of staying small and quick spooling and really want simple bolt on, i don't want to get into special manifolds or bracketry. I am looking to return to the days of 1 wire to run the motor and the simplicity it afforded. Of course i am planning on slipping it into a 2dr hardtop mk1. So any thoughts ideas experiments you have considered and never tried? hummm where did i put the old dial indicator!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #1July 26, 2011, 03:03:13 pm
Re: Mtdi mk1 rabbit Information wanted!!
« Reply #1 on: July 26, 2011, 03:03:13 pm »
i got one in my burnt toast project.. :D
as of now im running the stock tdi turbo.. boost reg easy build.. use a air pressure reg like they have on paint guns for painting cars.. i plan to go bigger this winter..
i used the rover pump due to cost.. gov mod.. have to use a mk4 style pully unless you get creative like i did making a adjustable pully like aftermarket cam gears.. runs pretty good... one day ill send it to giles to work over.. but for now there is no reason too..
Reply #2July 26, 2011, 03:43:09 pm
BigVWman
  • 332
« Reply #2 on: July 26, 2011, 03:43:09 pm »
I have been reading some of your project! I suspect its part of my underlying inspiration!
Tim
