Author Topic: Reverse switch for gearbox  (Read 3590 times)
July 22, 2011, 06:08:52 pm
Hiho
  • 77
« on: July 22, 2011, 06:08:52 pm »
Hi everyone,
I have a gearbox with the 5 of 8 pin reverse switch plug. Unfortunately the pins have corroded and snapped off. I believe any of the multi pin type switches will work. Postage is to Australia. Also, a 16 tooth speedo cable drive gear would help the cause....
Cheers!
Matt
1978 1.5 GLD
1978 1.6D soon to be TD
Reply #1July 22, 2011, 07:01:21 pm
Re: Reverse switch for gearbox
« Reply #1 on: July 22, 2011, 07:01:21 pm »
You can take old switches apart, I did that and swapped internals around to make it work. Then I got LED backup lights to lower the current through the switch.
Reply #2July 22, 2011, 08:54:15 pm
« Reply #2 on: July 22, 2011, 08:54:15 pm »
they sold 2 or 3 different pin layouts for that switch.. so you gotta get the right one..
also you will want to add in a load reduction relay to power the back up lights.. else it will just melt/ruin another swich down the road..
