Author Topic: Difference between 1Z and AFN Engine  (Read 11321 times)
July 20, 2011, 01:15:26 am
baldone
« on: July 20, 2011, 01:15:26 am »
What is the difference between 1Z and AFN engine? Besides to the AFN is more powerful.
Reply #1July 20, 2011, 05:26:39 am
Re: Difference between 1Z and AFN Engine
« Reply #1 on: July 20, 2011, 05:26:39 am »
Motor 1z :                 AFN
Turbo    GT15.           VNT 15 (gV)
Injector 0,187.           0,205
Pompe vanne différente
Calculateur ...
Reply #2July 20, 2011, 11:52:57 pm
baldone
« Reply #2 on: July 20, 2011, 11:52:57 pm »
Thank's!! ;)
Reply #3July 24, 2011, 11:11:19 am
snakemaster
  • 405
« Reply #3 on: July 24, 2011, 11:11:19 am »
afn valve stems are 1mm smaller , and the pistons are ment to be stronger
Reply #4July 30, 2011, 02:35:51 pm
« Reply #4 on: July 30, 2011, 02:35:51 pm »
Not piston, just ressor  ;)
Reply #5August 06, 2011, 08:18:08 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #5 on: August 06, 2011, 08:18:08 pm »
The injector pumps are different (cam plate is the biggest difference I think)
The injector nozzles
the rod bearings utilize sputter bearings for the top pieces
VNT turbo with a divorced turbo manifold
different turbo inlet pipe
different oil feed and return lines
different downpipe and flanges
The pistons are different
different N75 valves
different ECU programming
The valves are the same part number on the AFN/AHU and even the 1Z
I just went through the process of converting my AHU Corrado to a VNt turbo and used a bunch of AFN parts: http://forums.tdiclub.com/showthread.php?t=293320
