Author Topic: TDI stumbles and miss fires  (Read 16282 times)
Reply #15June 27, 2011, 03:40:55 pm
catlin_cava
  • 1954
Re: TDI stumbles and miss fires
« Reply #15 on: June 27, 2011, 03:40:55 pm »
check coolant temp in engine with vag-com when misfiring is occuring. possibly a bad CTS?
Would it cause the timing?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #16June 27, 2011, 03:53:35 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #16 on: June 27, 2011, 03:53:35 pm »
Very much so. timing is based on inputs to the ECU from things like the CTS and FTS, MAF, pedal position, etc.
Reply #17June 27, 2011, 04:04:47 pm
catlin_cava
  • 1954
« Reply #17 on: June 27, 2011, 04:04:47 pm »
I'm pretty sure my buddy looked at the coolant temp on the vag and said it was good,
Catlin
Reply #18June 28, 2011, 04:09:22 am
catlin_cava
  • 1954
« Reply #18 on: June 28, 2011, 04:09:22 am »
The car was a real pain to start cold, it would crank and crank and crank, we tried to adjust the IQ and no go, I did the hammer mod and the car fires up faster and isn't missfiring when first started, now you can feel the DMF going,
There still seems to be a bit of hesitation after she's syarted and you leave but when it's warm it's got wayyyyy more power
Catlin
Reply #19June 28, 2011, 10:12:44 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #19 on: June 28, 2011, 10:12:44 am »
Did this problem start all of the sudden? Was it running fine one day and then the next day it started misfiring and such?
Reply #20June 28, 2011, 04:53:05 pm
catlin_cava
  • 1954
« Reply #20 on: June 28, 2011, 04:53:05 pm »
It would changed from 5 minutes to another, i won't be fixing it for a bit, thr turbo over boosted blew an intercooler line and thru it into the powersteering pump blowing a huge hole in it with possibly plastic going into the motor
Catlin
Reply #21June 29, 2011, 01:36:29 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #21 on: June 29, 2011, 01:36:29 pm »
Was this problem present before blowing off the charge pipe? Is the intake manifold clean?
Reply #22June 29, 2011, 01:37:49 pm
« Reply #22 on: June 29, 2011, 01:37:49 pm »
Yes to both questions.
Reply #23June 29, 2011, 03:27:35 pm
catlin_cava
  • 1954
« Reply #23 on: June 29, 2011, 03:27:35 pm »
Yea I cleaned the intake my car only has 230,000kms on it, the IQ was out of whack again so I'm positive it's the pump, but no worries I'm tearing thr motor apart soon to start rebuilding it,
Catlin
Reply #24June 29, 2011, 07:38:45 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #24 on: June 29, 2011, 07:38:45 pm »
Ok, so are you saying nevermind, lets not worry about it anymore? :p
Reply #25June 30, 2011, 07:21:00 pm
« Reply #25 on: June 30, 2011, 07:21:00 pm »
he's saying 11mm pump :)
Reply #26June 30, 2011, 07:41:24 pm
catlin_cava
  • 1954
« Reply #26 on: June 30, 2011, 07:41:24 pm »
Catlin
Reply #27June 30, 2011, 08:22:08 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #27 on: June 30, 2011, 08:22:08 pm »
Why not a 12mm?
Reply #28July 01, 2011, 03:36:38 am
catlin_cava
  • 1954
« Reply #28 on: July 01, 2011, 03:36:38 am »
Why not a 12mm?
Don't even tempt me lol I would is the worst part just so I can scare the *** out of a few friends lol
Catlin
Reply #29July 01, 2011, 11:58:39 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #29 on: July 01, 2011, 11:58:39 am »
soooo 12mm then? :p
