Author Topic: Let's talk EGT's for boosted NAs  (Read 4090 times)
June 23, 2011, 06:35:56 am
vdubspeed
  • 191
« on: June 23, 2011, 06:35:56 am »
So I took a 1.6 N/A and slapped on a 98 TDI turbo, built a 2.25 exhaust, gov mod, fuel screw in 1.5 turns, rotate 1 spline CCW, and slapped in an EGT gauge...but no intercooler.
This thing is WAY faster than it used to be and can easily pull away from traffic at the lights.
Here comes the downside...HIGH EGTs
If I floor it I can see 1500 degrees but I never stay there for more than a second. That's when I'm showing off the car. Generally I never go past 1100. That's where the alarm is set to come on.
Cruising yields 800-900 temps when going down the highway in 95 degree weather.
The car runs AWESOME but I don't want to hurt it. Am I?
Thanks,
Jason
Reply #1June 23, 2011, 07:13:51 am
Re: Let's talk EGT's for boosted NAs
« Reply #1 on: June 23, 2011, 07:13:51 am »
Possibly. I try to stay at or under 1,200F. Aluminum melts right around there and our heads are made of that. Are pistons are certainly some Al alloy. I can see 1,500F and then back off as I really don't want to go more than that ever. Cruising I see around 500F to 1,000F depending on flat ground or hills in 5th. If I were you I would turn down the fuel screw 1/8th of a turn or until you see 1,400 max and still have performance. Or leave it where it is and don't let anyone drive it but you.
Reply #2June 23, 2011, 07:58:26 am
« Reply #2 on: June 23, 2011, 07:58:26 am »
what are you using for an intake? Thought about getting an intercooler?
the 98 came with a k03, so its gonna preeeetty restrictive at higher rpm's as it makes its peak boost at 1900 on the tdi motor. Do you have the wastegate changed at all? or stock from the tdi?
Reply #3June 23, 2011, 08:11:40 am
81 vw pu
« Reply #3 on: June 23, 2011, 08:11:40 am »
OK guys, for $1500 I will purposely melt down my 1.6 on video so we can put this question behind us.
Maybe even some side bets on what temp and how long it takes.
30 guys x $50 each, any takers. ;D
Reply #4June 23, 2011, 08:35:33 am
« Reply #4 on: June 23, 2011, 08:35:33 am »
To do the kind of research I would want would take more than that. I would want to see what it did to the pistons/engine after 30 seconds of EGT's at various temps. So you would need to keep taking the HG off and inpecting. I would send you a couple TD badges for free if you did melt yours down though for my contribution.
Reply #5June 23, 2011, 09:04:18 am
81 vw pu
« Reply #5 on: June 23, 2011, 09:04:18 am »
I don't think my old run down back would like pulling the head multiple times, but I have thought about drilling a hole in a old piston insert the egt probe and heat with a torch.
Even try the same on a old cracked/warped head. Only bad part with this test is missing the coolant flow and oil squirters on the pistons.
Reply #6June 23, 2011, 09:51:18 am
Powered by Spearco
  • 1203
« Reply #6 on: June 23, 2011, 09:51:18 am »
I got $30 on it.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #7June 23, 2011, 10:10:47 am
« Reply #7 on: June 23, 2011, 10:10:47 am »
i already burned one down once.. and im still driving it..
it seized up from high EGTs.. how high tho, i will never know..
you wont melt down the engine.. it will seize before anything gets hot enough to melt.. the piston to bore clearance is soo small, that any piston growth at all, pretty much makes the piston too big to go up and down anymore..
i guarantee you that i could pull my engine apart, and the most damage there would be, is scuffed piston skirts, and maybe a little erosion right under the swirl chamber..
im half tempted to take it apart just to prove to you guys that these engines are TOUGH..
i was holding the throttle wide, at 100 mph, turning like 5500 revs, making ~25 psi un-intercooled boost.. on a 3 mile long hill.. well, lets just say that my engine only made it 2.5 miles, and the other half mile to the top was done coasting.. good thing i had 100mph of momentum to carry me over the top..
Reply #8June 23, 2011, 10:50:55 am
81 vw pu
« Reply #8 on: June 23, 2011, 10:50:55 am »
Well here's the first bet!!! I got $20 says I can transfer melted piston aluminum to the cylinder walls before it seizes.
Provided I get the full $1500 for the test.
And by the way I'm just bored and trying to have some fun. ;D
Reply #9June 23, 2011, 04:05:19 pm
« Reply #9 on: June 23, 2011, 04:05:19 pm »
hill folk told me before that he ran an na motor up into the 1600 range with out anything bad happening, honestly if no one is sustaining that high of temps i don't see it hurting anything all that much, ok your exhaust temps are 1500, and probably a little bit higher inside the cylinder, but the metal has to absorb that heat from the air before it would ever even begin to melt, and you figure the cylinder is only that hot for half of the combustion process, the other half is intake and compression stroke, honestly i think burnt valves will be a problem before the pistons would be.
i had a bad injector cause a cracked head before, who knows what temps it took to do that, it probably didn't help that only that cylinder was getting that high of temps, but that piston really looks quite fine aside from a wider burn mark on it.
Reply #10June 23, 2011, 08:48:53 pm
RadoTD
  • 513
    Stage WTF
« Reply #10 on: June 23, 2011, 08:48:53 pm »
I'm in for $30 as well!
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #11June 24, 2011, 12:22:32 am
keaton
  • 90
« Reply #11 on: June 24, 2011, 12:22:32 am »
i'm in to come pick up the car and drive it home.
2006 1.9L BRM 5-speed Manual... 100% Stock :(
Standalone VGT/VNT controller: http://dmn.kuulalaakeri.org/vnt-lda/
My CAN Bus video recorder: http://www.youtube.com/watch?v=2QuRBQzGs-c
Reply #12June 24, 2011, 02:02:15 pm
« Reply #12 on: June 24, 2011, 02:02:15 pm »
$50 says i already transferred aluminum to my bores, and scrubbed it clean with my rings..
Reply #13June 25, 2011, 05:26:14 am
vdubspeed
  • 191
« Reply #13 on: June 25, 2011, 05:26:14 am »
wow...funny feedback.
I'm glad I have a few more N/As outback if this one pops. I'll look into an intercooler fo sho.
Reply #14June 25, 2011, 04:43:42 pm
keaton
  • 90
« Reply #14 on: June 25, 2011, 04:43:42 pm »
hey if your just gonna melt it down/ blow it up i'll come take it off your hands  ;D
i'm diesel'less and having a hard time finding one  :-\
