Author Topic: Some stuff for sale  (Read 5897 times)
June 20, 2011, 09:22:27 am
sawedoffgolf
  • 213
Some stuff for sale
« on: June 20, 2011, 09:22:27 am »
Cleaning out the garage and i found some diesel parts, i dont drive one anymore so basically everything you see here has to go. I dont have any set prices in mind so make an offer.
pic1:
1.6na injector pump off 90's golf
1.9td injector pump off 94 golf
pic 2:
1.9 alternator
1.9 alternator bracket, non ac
pic 3:
1.6td intake manifold
1.6td valve cover
pic 4:
1.9td turbo oil feedline x2
mk2 cast 1.6td downpipe
mk1 1.6td vacuum pump
4 1.9td aaz injectors
4 1.6td injectors
1.9td oil breather hose/baffle
2 90 degree hoses (turbo to intake) off 1.9td
beetle tdi upper intercooler hose
roughly 2 dozen good glowplugs, they were spares, couple alh glow plugs in there aswell.
Reply #1July 20, 2011, 01:08:37 pm
sawedoffgolf
  • 213
Re: Some stuff for sale
« Reply #1 on: July 20, 2011, 01:08:37 pm »
Bump, also have a set of rebuilt 1.6td injectors with gtd nozzles, haven't been installed yet,they have been pop tested. I also got a set of timing tools and diesel compression tester kit.
Reply #2July 21, 2011, 06:09:31 am
Ziptar
  • 565
« Reply #2 on: July 21, 2011, 06:09:31 am »
$5.00 for all of it?
Reply #3July 22, 2011, 12:51:41 am
sawedoffgolf
  • 213
« Reply #3 on: July 22, 2011, 12:51:41 am »
Sure, shipping will be about $345 to you ;D
Reply #4July 23, 2011, 11:48:38 am
Ziptar
  • 565
« Reply #4 on: July 23, 2011, 11:48:38 am »
That's Ok, I'll Pickup.  ;)
Reply #5July 29, 2011, 06:56:00 pm
dodger21
  • 97
« Reply #5 on: July 29, 2011, 06:56:00 pm »
How much for the 1.9TD IP and 1.6TD injectors?
1985 Golf 1.6NA with a 5spd
Reply #6July 31, 2011, 12:51:43 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #6 on: July 31, 2011, 12:51:43 am »
Q: will the injector pump work for an older 1.5? Will I have to send it to the Jedi Master?
thanks,
Kev
Reply #7August 01, 2011, 12:11:49 am
sawedoffgolf
  • 213
« Reply #7 on: August 01, 2011, 12:11:49 am »
thanks,
Kev
the 1.9td pump is now sold, unless you are talking about the 1.6na pump which i believe should work, i dont know much about the 1.5 diesels.
Reply #8August 01, 2011, 08:50:51 pm
wdkingery
  • 494
« Reply #8 on: August 01, 2011, 08:50:51 pm »
how much for the td intake manifold?
Reply #9August 07, 2011, 11:53:32 am
madmedix
  • 204
« Reply #9 on: August 07, 2011, 11:53:32 am »
pm'd ya  ;D
'90 TD Jetta
Reply #10August 07, 2011, 01:51:31 pm
sawedoffgolf
  • 213
« Reply #10 on: August 07, 2011, 01:51:31 pm »
$20+ shipping for the td manifold?
Reply #11August 09, 2011, 11:47:21 am
madmedix
  • 204
« Reply #11 on: August 09, 2011, 11:47:21 am »
pm'd you; I'll take the kits.
Andy
'90 TD Jetta
Reply #12August 27, 2011, 02:30:48 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #12 on: August 27, 2011, 02:30:48 pm »
Any of this stuff still around? If so I'd be interested in the 1.6 downpipe, an oil supply line, and those 1.6 injectors you mentioned in your second post.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #13September 06, 2011, 03:43:22 am
« Reply #13 on: September 06, 2011, 03:43:22 am »
I'd hold off on anything here. He has yet to send me what I've paid for.
Andy
i also PM'd him a few times, with no responses..
never bought anything from him tho, but was thinking about it..
Reply #14September 06, 2011, 11:32:09 am
81 vw pu
« Reply #14 on: September 06, 2011, 11:32:09 am »
Andy
I got a few things from him awhile back and had no problems.
