Author Topic: How much different are AAZ and MF pumps.  (Read 4902 times)
June 09, 2011, 10:18:15 pm
« on: June 09, 2011, 10:18:15 pm »
I am looking at possibly getting an AAZ to swap in place of my 1.6 n/a in my 84, as I miss the joyous laughter that comes from boost. LoL
And I think the only thing I am not entirely sure about is the aaz pump, I have never personally seen one nor have I worked on one. Will it bolt up to the Mk1 1.6 diesel passenger mount that holds the pump? I know the mount will physically fit the engine, but will the pump fit the mount?
Other than that, I think the downpipe is the only other brain tease. I've got ALL other diesel engine swap related crap down to a frikken T.
Also is there any particular years to look out for? reagarding turbo's? Or did all AAZ's get the same equipment? and what turbo what that be?
Reply #1June 10, 2011, 08:49:30 am
Re: How much different are AAZ and MF pumps.
« Reply #1 on: June 10, 2011, 08:49:30 am »
Nothin' eh :p lol
Reply #2June 10, 2011, 12:43:58 pm
catlin_cava
  • 1954
« Reply #2 on: June 10, 2011, 12:43:58 pm »
Go buy that mk4 and have fun like me and Guillaume lol no aaz will keep up to us lol
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3June 10, 2011, 03:27:37 pm
« Reply #3 on: June 10, 2011, 03:27:37 pm »
an AAZ in a light mk1 or mk2, would not take much power to over take a bloated mk4.. what do you weigh, almost 3k lbs?
Reply #4June 10, 2011, 05:34:18 pm
« Reply #4 on: June 10, 2011, 05:34:18 pm »
Truth, but Catlin and Guillaume have pretty heavily modified TDI's. Catlin's pulls from idle to redline, and will easily and quickly bury the speedo and keep going..!
HOWEVER! I do agree alot less HP and TQ in an mk1 will be the same.
So my question still stands, will the 1.9 pump fit on the 1.6 bracket? Better yet, Can I use the 1.6 TD pump I have? I hear they are more tun-able.
Reply #5June 10, 2011, 05:41:36 pm
« Reply #5 on: June 10, 2011, 05:41:36 pm »
i know those guys are NOT running stock cars.. i wasnt talking about them in particular, just in general.. mk1 and mk2 cars are WAY lighter is all..
think of how nuts it would be to have a mk2 gti and a fire breathing ALH in it?  ;D
(yes jeremy, the pumps bolt up the same, but the AAZ pump/lines/injectors are all specific. to get everything to fit like factory, you have to use the matching pump, lines, and injectors)
Reply #6June 10, 2011, 05:45:20 pm
« Reply #6 on: June 10, 2011, 05:45:20 pm »
So i would need to use 1.6 pump, lines and injectors if i wanted to use the 1.6 setup.. Would it matter between n/a and turbo injectors?
I agree it would be awesome with a fire breathing TDI. I still might just swap my tdi in my 84 if I dont get this AAZ...
Reply #7June 10, 2011, 05:53:25 pm
« Reply #7 on: June 10, 2011, 05:53:25 pm »
you might even be able to use the short AAZ injectors, but im not positive..
i would use the 155bar TD injectors. well, let me correct myself, i would use the ones in best shape..
but the 155bar injectors atomize fuel a little better under boost..
Reply #8June 10, 2011, 05:57:40 pm
« Reply #8 on: June 10, 2011, 05:57:40 pm »
Ahh yes, well unfortunately I do not have 155bar td injectors :( lol
So I guess full 1.9 fueling setup it is, with the 1.6 td pin then.. OR JUST GROW A PAIR AND MAKE WAY MORE POWER WITH MY AHU... Hmmm
Reply #9June 10, 2011, 06:34:05 pm
catlin_cava
  • 1954
« Reply #9 on: June 10, 2011, 06:34:05 pm »
And we aren't done with those cars  ;D
Catlin
Reply #10June 10, 2011, 07:44:06 pm
rallydiesel
  • 1880
« Reply #10 on: June 10, 2011, 07:44:06 pm »
I don't have an AAZ pump on hand to compare, but I seem to recall the AAZ has a different spacing on the sprocket compared to a 1.6 pump. I'm not sure the sprocket would line up properly with the timing belt. Don't quote me on that but definitely check it out beforehand if you can.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #11June 11, 2011, 10:37:42 am
« Reply #11 on: June 11, 2011, 10:37:42 am »
If you have all the 1.6 stuff now, use it.  You will definitely have a running engine, and more than enough fuel to push your car around.  Remember a lot of the AAZ injector design is just to reduce noise / help emissions.
The 1.9 pump does have a better cam plate so it does have more power potential.  But if you are going to try to chase down a new pump then you might as well just send your 1.6 pump to Giles!!  You'll get back the best possible pump for what you have.
Reply #12June 11, 2011, 11:12:53 am
« Reply #12 on: June 11, 2011, 11:12:53 am »
I have the 1.6 TD pump right now with a N/a top on it right now in my 84. I have the TD top and the td injector lines but no td injectors..
I figure I will put my time and money towards getting my TDI in my 84 :) its gonna be quiiick.
