Car is a 1983 Rabbit 1.6 non turbo.
I've been putting this car together from about 3 parts cars, and an older bentley manual. (both of these things factoring in to my problems). My manual only goes up to 81, and wiring diagrams only thru 1980. Engine is bottom end Quantum turbo diesel, mechanical top end original to car -1983 rabbit LS.
Motor is fresh, new rings, rods, mains, oil pump, re-did head, starts, runs drives terrific. Been driving it for 2 days now.
Question is with the oil light. Looked at Vince Waldon site, and just cannot figure out my deal here, doesn't make sense.
Question #1 is- Do I have my wiring right?
Should my car need - have- a W-terminal for alternator? The alternator that is on the car which I believe is not working does have a W-terminal. I believe that the alternator is bad because after 2 days of use, the battery is now dead. My instrument cluster does not have a tach- just a clock.
Going to the W-terminal is a heavy gauge black/grey stripe wire with a heavy plastic connector end.
As for the high pressure sensor on the oil filter housing, this wire is a thin blue (solid blue/lighter gauge wire) with a heavy plastic connector end. This blue wire and the black/Grey stripe are both in a little harness with the connectors for the shift light that go on the injection pump for a car with the shift light.
The sensor in the head has a white/black stripe wire going to it. This wire also has the heavy black plastic connector on it. In that cluster of wires, there is also a blue/yellow and a blue wire which are both hooked up to the coolant inlet in side of the head.
Question #2- What's the deal with this oil light?
When I switch the key on (not starting the engine) the oil light does NOT come on. After the car starts, when the battery is at full charge the light remains off. When the battery is going dead, the oil light starts to come on. I looked at Vince Waldon site and did a few searches here to diagnose.
Ignition ON, car not running, sensor in head is closed as confirmed by running test light from positive battery terminal to the sensor- light comes ON when ignition on/car not running. Once car is running, same test of head sensor shows that once car is running, sensor opens as confirmed by test light positive battery to sensor yields test light off. I think this is telling me I have oil pressure at the head.
Testing the sensor in the oil filter housing the same way, when ignition is on, engine not running, the high pressure sensor circuit is open, test light does not come on. Start the car, and the test light to the filter sensor will come ON and stay on- even at idle.and stays on a second after engine is shut off. I think this is telling me that I have oil pressure at the filter.
Those 2 things checking out that we do have oil pressure, light is still on, constant, no buzzer, not flashing
Question #3- What's the deal with this battery light? How do I test the battery light?
Although the battery does not appear to be charging, the battery light does not ever come on. It does not come on when the car is not running with the ignition switch turned on position. The previous owner had an amp meter installed, and the wiring harness was all cobbled up. The alternator I have on the car is the original alternator. I used a different un-molested harness from a different car. I pulled a the whole new harness - fuse box and all, If I recall correctly the car it came from was an 84.
Question #4 - Can I use this alternator?
I have an alternator that I was told was known to be good, and newly purchased by a guy that gave me a bunch of parts. The case is stamped with a W, but there is no wire terminal to hook to, just a hole in the case. I don't have this on the car, but will swap it in if the W terminal is something not needed or otherwise.
Thanks for reading and replying.
I do not need this car for transportation, but would like to figure out the problem if someone would be so kind to help. I have time to work on the car this weekend, but a lot of stores are closed. Things I already know: I need to get a newer Bentley. An oil pressure gauge is in my future as soon as stores open up after the holiday weekend. Autozone tests alternators and will have mine tested on tuesday.
I am pretty convinced that I've got some wires hooked up wrong the more I think about it. But any help in the mean-time is appreciated.
