Author Topic: lopey idle, lots of gray smoke  (Read 4343 times)
May 24, 2011, 05:25:27 pm
dieselherb1
  • 354
« on: May 24, 2011, 05:25:27 pm »
1.6TD(from Quantum) in caddy, head resurfaced and valve job. Had trouble starting it, now runs idle rough and lots of gray smoke(don't have exhaust pipe on it yet so smokey under the hood. Set timing at .39 I think dial indicator mount sloppy. Your thoughts?
Thanks!
Reply #1May 24, 2011, 07:20:27 pm
BillyWillicker
  • 111
Re: lopey idle, lots of gray smoke
« Reply #1 on: May 24, 2011, 07:20:27 pm »
Dont have much exp. with these but Spec is .95
Reply #2May 24, 2011, 07:49:46 pm
wdkingery
  • 494
« Reply #2 on: May 24, 2011, 07:49:46 pm »
the rebuild is all bad the motor is trash..
hey i'm in VA too wanna sell?
haha j/k (or not) but yeah you got bad timin fo show fo show.. get it strung on out to the .95 and that smokin will clear up
Reply #3May 25, 2011, 06:45:18 am
dieselherb1
  • 354
« Reply #3 on: May 25, 2011, 06:45:18 am »
My indicator is in inches .39 I believe is 1.05mm? Not sure how accurate the setting though mount sloppy. I'm thinking I should retard it a little?
Reply #4May 25, 2011, 06:51:54 am
JessaBug
  • 112
« Reply #4 on: May 25, 2011, 06:51:54 am »
I hope that 0.039in! If so, thats more like .99mm. Not really all that far off, but you could try bringing it down to .95mm to see if it helps (0.0374in).
Do you have the right adaptor for the timing gauge? I know ours came with different ones, but we also have one that reads in mm. It needs to be secure, otherwise you will never get your timing correct on the pump.
« Last Edit: May 25, 2011, 06:53:28 am by JessaBug »
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #5May 25, 2011, 06:54:17 am
  • 1739
« Reply #5 on: May 25, 2011, 06:54:17 am »
I'll look when i get in to the garage later, but ,yes .39 is pretty high. I would set it at around .35 or just retard it while running to see where it likes it best. Double check the belt timing also and make sure your timing advance is pushed in and is really set back by looking at the lever
Reply #6May 25, 2011, 07:55:53 am
« Reply #6 on: May 25, 2011, 07:55:53 am »
If you haven't ran it 10 miles or more I wouldn't worry. It took me that long to burn the oil and get the air out from when I reassembled the engine. 1.00mm should be fine I would think retarding it would cause more smoke at idle. Does it clear up when reved? IIRC the spec is between .033 and .042" depending on engine
Reply #7May 25, 2011, 01:49:22 pm
« Reply #7 on: May 25, 2011, 01:49:22 pm »
I would check the timing over, check to make sure ALL glowplugs are working, make sure you don't have air leaks.. They can cause a hell of a nightmare.
also is the pump a fresh rebuild? How many kms?? Older pumps like to be around .039 to 0.41. I have my NA times to 0.040 I believe.
Reply #8May 25, 2011, 06:11:50 pm
dieselherb1
  • 354
« Reply #8 on: May 25, 2011, 06:11:50 pm »
83 TD pump, new seals front and rear, Idle better now(after I ran it around 10-15 min) But not alot of power, have to rev it up to move in first. Still alot of smoke even after running awhile. I'm going to check timing again
Reply #9June 15, 2013, 08:31:21 am
srgtlord
  • 797
« Reply #9 on: June 15, 2013, 08:31:21 am »
Did you ever solve this issue?
Reply #10June 15, 2013, 09:52:30 am
« Reply #10 on: June 15, 2013, 09:52:30 am »
This was likely the issue.
Reply #11June 15, 2013, 09:55:51 am
masterbeavis
  • 88
« Reply #11 on: June 15, 2013, 09:55:51 am »
My motor smoked after being put back together with a used pump. The timing was set to spec, it ran sub-ok.  While running the smoke would stop if I pulled the cold start valve. That suggested my timing was regarded.  Eventually I just pushed the pump further to the motor, it ran better, the smoke went away.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
