Author Topic: Oil changes  (Read 43297 times)
Reply #105June 23, 2011, 10:54:30 am
Vangruver
  • 162
Re: Oil changes
« Reply #105 on: June 23, 2011, 10:54:30 am »
I just swapped over from 155.80.13 winters on OEM vw alloys to 205.50.15 performance summers on OEM corrado steelies.
HUGE difference in acceleration and hill climbing, but much better over all cruising and corner speed entry/exit. Makes me want to have an intercooler quick just in general.
It's mainly for highway cruising and the occasional corner carving. As I don't see myself keeping these tires on for longer than 6 months out of the year. The other 6 months will have the winters for my mountain expeditions.
Reply #106June 23, 2011, 11:05:00 am
81 vw pu
Re: Oil changes
« Reply #106 on: June 23, 2011, 11:05:00 am »
Rim size is not a factor, its the overall diameter of the tires that changes your gear ratio.
a 185/70/13 is most definitely smaller than a 185/70/14..
Could very well be, I don't have the two to measure. But rim size doesn't affect your odometer/mileage, its the circumference of the tire.
Reply #107June 24, 2011, 01:59:20 pm
Re: Oil changes
« Reply #107 on: June 24, 2011, 01:59:20 pm »
rim size may not directly affect your odometer, but the bigger tire circumference on that wheel sure will make the odometer..
look you guys, im not talking to hear my brains rattle.. bigger tires and rims will make a difference.. 185/70/14 tires are big on a mk2, and HUGE on a mk1.. they DO make your odometer read slow, and 185/70/14's ARE BIGGER than 185/70/13s.. over an inch taller..
Reply #108June 24, 2011, 03:10:34 pm
Re: Oil changes
« Reply #108 on: June 24, 2011, 03:10:34 pm »
He isn't joking...nor was I :D
http://www.scirocco.org/gears/
Reply #109June 24, 2011, 04:09:29 pm
Re: Oil changes
« Reply #109 on: June 24, 2011, 04:09:29 pm »
205/50/15      (this size just used as example, because the math was easy to do in my head)
205mm wide, side wall being 50% of the width of the tire (102.5mm in this case) on a 15" wheel..
if the tire size does not change, but the rim size does (205/50/16) then the tire height will increase atleast 1" from the bigger wheel..
the tire is still 205mm wide, and the sidewall is still 102.5mm, so there is NO WAY IN HELL that a 205/50/15 and a 205/50/16 are the same size.. width, yes.. height, not even close..
your 185/70/14s are ATLEAST 1" taller than your same tires on 13" wheels.. you WILL LOSE FUEL ECONOMY. if i lost 3mpg on my gasser, i expect you to see similar losses..
metric tires are measured by width, and sidewall aspect ratio, not the actual width and height like SAE tires.. (a 31x10.50, is still a 31x10.50 no matter what diameter of wheel is inside it)
with metric tires, if the tire size stays the same, but the wheel size increases, the tire diameter increases also.. plain and simple.. if you dont believe me, Wikipedia that S#!T or something...
« Last Edit: June 24, 2011, 05:47:56 pm by R.O.R-2.0 »
Reply #110June 24, 2011, 05:02:04 pm
81 vw pu
Re: Oil changes
« Reply #110 on: June 24, 2011, 05:02:04 pm »
(a 31x10.50, is still a 31x10.50 no matter what size wheel is inside it)
Rim width will change the OD of the tire, found that out the hard way. Had to move my exhaust when I went from 10" to 8" rims with the same tires on my jeep.
Reply #111June 24, 2011, 05:47:15 pm
Re: Oil changes
« Reply #111 on: June 24, 2011, 05:47:15 pm »
im talking wheel diameter tho, not width..
Reply #112June 24, 2011, 06:01:25 pm
Re: Oil changes
« Reply #112 on: June 24, 2011, 06:01:25 pm »
100% correct.
Reply #113June 24, 2011, 06:47:00 pm
81 vw pu
Re: Oil changes
« Reply #113 on: June 24, 2011, 06:47:00 pm »
100% correct.
And a 185/60/14 is smaller than a 185/70/13, and my point is just because the rim is bigger doesn't always mean the tire/wheel combo will be a bigger diameter.
You very well could end up with identical diameters between various 13" and 14" tire and wheel combinations, but overall diameter is whats gonna affect speedo and mileage.
Reply #114June 25, 2011, 10:52:09 am
Re: Oil changes
« Reply #114 on: June 25, 2011, 10:52:09 am »
100% correct.
im 100% aware..
the bigger, heavier wheel will achieve less economy tho..
ive never disagreed with you about wheel diameter..
all im saying, is that if you have 2 of the same size tires, with different wheels size, then the tires are not the same size..
Reply #115June 27, 2011, 03:00:50 pm
blackbird82
  • 151
Re: Oil changes
« Reply #115 on: June 27, 2011, 03:00:50 pm »
Wow, you guys really worry about tires!
I love the whistle......
Reply #116June 27, 2011, 03:02:00 pm
Re: Oil changes
« Reply #116 on: June 27, 2011, 03:02:00 pm »
Even more worry and bickering over 2-3mpg :O.. lmao Every day above 20 is GOOD FOR ME :D:D
Reply #117June 27, 2011, 03:52:12 pm
Re: Oil changes
« Reply #117 on: June 27, 2011, 03:52:12 pm »
its not about that.. its about being correct, and people thinking otherwise.. when ive been there and done that, got the t-shirt.. i know what happens..
and i know a thing or 2 about tires.. especially that metric tires and SAE tires are measured differently..
Reply #118June 27, 2011, 09:24:58 pm
DieselBalz
  • 301
Re: Oil changes
« Reply #118 on: June 27, 2011, 09:24:58 pm »
Well I am still gettin an MPG done, and will have results soon (not that they are some deciding factor). But to swing it back around to the oil changes, how about some filter talk?
Found this over on Vortex http://forums.redflagdeals.com/important-oil-filters-1005723/
I am so happy I have Mann filters for the Eco I bought a 3 pack when I got it..
Now I need to figure out a better filter for the F150.
Reply #119June 28, 2011, 05:51:29 am
blackbird82
  • 151
Re: Oil changes
« Reply #119 on: June 28, 2011, 05:51:29 am »
JD Filters all the way
