Author Topic: Oil changes  (Read 42326 times)
Reply #120June 28, 2011, 11:38:45 am
Re: Oil changes
« Reply #120 on: June 28, 2011, 11:38:45 am »
Do you have a JD part # that works on our diesels?
Reply #121June 28, 2011, 12:46:26 pm
  • 4549
Re: Oil changes
« Reply #121 on: June 28, 2011, 12:46:26 pm »
Blackbirds gave us this on Page 4 of this thread.
Oh if you have access to a John Deere dealer.
the part number is TY9425E
Reply #122June 28, 2011, 12:51:52 pm
Re: Oil changes
« Reply #122 on: June 28, 2011, 12:51:52 pm »
Sorry there has been like 563 posts about nothing to do with oil changes at all.. Hard to keep track, plus I'm on my phone so I can't see the whole thread at a time.. Only a few posts.
Reply #123June 28, 2011, 04:59:49 pm
DieselBalz
  • 301
Re: Oil changes
« Reply #123 on: June 28, 2011, 04:59:49 pm »
Sorry bout that.
Reply #124June 28, 2011, 08:00:33 pm
  • 4549
Re: Oil changes
« Reply #124 on: June 28, 2011, 08:00:33 pm »
yeah, kind of morphed into a discussion on rolling parts not lube.  And it got kind of tense a few posts.
Reply #125June 29, 2011, 01:25:44 pm
Re: Oil changes
« Reply #125 on: June 29, 2011, 01:25:44 pm »
it gets intense all in the name of VWs!
Reply #126June 30, 2011, 08:10:23 am
blackbird82
  • 151
Re: Oil changes
« Reply #126 on: June 30, 2011, 08:10:23 am »
Ha, ya. All in all. I change my oil every 4,000k or as it happens to be. every month.  I use the JD filter and usually run 5w40 Synthetic Duron XL Petro-Canada Oil. It has the JX extreme testing spec. Very good to look out for.
I also before changes, as it is usually a little lower add 1liter of diesel to the oil and idle it for 25 min.
But I need to removed the oil cooler and change the o-rings in there. leaks around my filter mount.
Peace.
Oh and it in cold cold Winterpeg today is 36 degrees Celsius and 99 percent humidity.
There goes my balls, I just sweat them off.
I love the whistle......
Reply #127June 30, 2011, 08:48:17 am
ToddA1
  • 434
Re: Oil changes
« Reply #127 on: June 30, 2011, 08:48:17 am »
Hmmmm...  I haven't used an engine flush in about 2 decades.  1 liter is about 20% of full oil capacity.  I wonder if it's safe to thin the oil that much.  At idle, it probably isn't a huge deal, but I wonder if adding about half a liter would be better/safer.
If you don't extend the oil changes by a rediculous number and use a quality filter, I'm wondering if it's needed at all.
-Todd
Reply #128June 30, 2011, 09:02:43 am
Re: Oil changes
« Reply #128 on: June 30, 2011, 09:02:43 am »
-Todd
i like dumping in a quart of ATF.. it has soo much detergent in it, and it cleans fast.. i should have taken before and after pics of my newest 8v that i flushed like that.. i was a quart low, so i topped back up with ATF, and my oil wasnt even that dark yet.. boy, the next few times i checked my oil, the stuff on the dip stick was getting darker. and got darker every time i checked, until i drained the oil.. i ran that quart for probably a week or more. under the valve cover, it was nasty before i ATF'd it.. and it was about spotless after the treatment..
Reply #129June 30, 2011, 10:08:22 am
ToddA1
  • 434
Re: Oil changes
« Reply #129 on: June 30, 2011, 10:08:22 am »
Won't ATF damage your seals?  I hear stories of it causing seals to leak.
-Todd
Reply #130June 30, 2011, 10:14:06 am
Re: Oil changes
« Reply #130 on: June 30, 2011, 10:14:06 am »
-Todd
if anything, it should SOFTEN your seals.. its not like i was running PURE ATF anyways..
ATF doesnt damage trans seals, and they BATHE in the stuff..
Reply #131June 30, 2011, 10:23:32 am
ToddA1
  • 434
Re: Oil changes
« Reply #131 on: June 30, 2011, 10:23:32 am »
Good point.
-Todd
Reply #132June 30, 2011, 10:29:25 am
Re: Oil changes
« Reply #132 on: June 30, 2011, 10:29:25 am »
Good point.
-Todd
im sure if you ran way too much ATF, it might soften your seals enough to make them tear..
i would worry more about diesel, or bio-diesel softening the seals of the engine, rather than ATF..
Reply #133June 30, 2011, 04:28:36 pm
maxfax
  • 2126
Re: Oil changes
« Reply #133 on: June 30, 2011, 04:28:36 pm »
Atf is one heck aof an amazing engine cleaner..   Works wonders with sticky noisy lifters!!  If you run atf through and a seal starts leaking, it was probably shot anyhow..  Especially on an older engine as it was the crud that was keeping the oil in..
Reply #134June 30, 2011, 04:31:46 pm
Re: Oil changes
« Reply #134 on: June 30, 2011, 04:31:46 pm »
ok, so that kinda goes along with my experiences.. cause it did have a ticking lifter before i ATF'd it.. now the lifters only tick until the oil light goes out.. maybe 3-5 ticks then silent.
because the oil in my gasser wasnt very dirty when i dumped the ATF in, then about 500 miles later, it was basically BLACK.
