Author Topic: Clean your TDI Intakes!!!!  (Read 8211 times)
May 15, 2011, 09:13:48 am
catlin_cava
  • 1954
« on: May 15, 2011, 09:13:48 am »
If you got 250K plus on your TDI Check your intake, it may need to be cleaned!!!! This is one off of a 2000 TDI with 355K on it
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1May 15, 2011, 09:56:20 pm
cyrus #1
  • 360
Re: Clean your TDI Intakes!!!!
« Reply #1 on: May 15, 2011, 09:56:20 pm »
That is brutal!  I checked mine when it had about 280,000 and it wasn't nearly that bad.  There was maybe 1/16" buildup in it.  You certainly have your work cut out for you there.  :o
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #2May 16, 2011, 01:13:14 am
« Reply #2 on: May 16, 2011, 01:13:14 am »
The more the merrier :D
Reply #3May 16, 2011, 05:32:37 am
Dennis Froelich
  • 258
« Reply #3 on: May 16, 2011, 05:32:37 am »
340,000 on my wifes 2000 TDI NB has never needed to be cleaned.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #4May 16, 2011, 10:30:09 am
Quantum TD
  • 1195
« Reply #4 on: May 16, 2011, 10:30:09 am »
You really need to drive them hard to clean out that gunk on a regular basis, or adjust the EGR duration. My car had that before I bought it, and it was cleaned out. EGR adaptation was done, and it's only got oil on the intake after 120K.
I would imagine your turbo is next. The vanes coke up too and will stick causing over or under boost.
Last one of these I did, I tried the propane torch + air hose trick. Man, it's slick at tits and hilarious to watch. It's like a flamethrower!  Much easier than trying to clean it through conventional means, and it doesn't do any damage to the intake. Though, the one I did had the EGR that came off. I'm not so sure I'd try in on an AHU or 1Z with the EGR that's part of the intake manifold.
« Last Edit: May 16, 2011, 10:50:10 am by Quantum TD »
Reply #5May 16, 2011, 10:50:33 am
« Reply #5 on: May 16, 2011, 10:50:33 am »
sweet, a 72-ish Chev pickup.. and a hood for one. i love those old trucks.  ;)
Reply #6May 16, 2011, 12:51:54 pm
« Reply #6 on: May 16, 2011, 12:51:54 pm »
There are a  Chev and a GMC in that pic, Chev needs the hood.
Reply #7May 16, 2011, 03:32:46 pm
« Reply #7 on: May 16, 2011, 03:32:46 pm »
yeah 67-72 were good years, pretty modern looking while still being classic.  my dad has a 67 small window short bed... cool trucks
Reply #8May 17, 2011, 09:16:56 pm
nathan_b
  • 361
« Reply #8 on: May 17, 2011, 09:16:56 pm »
mr bently says tdi intakes are usable as long as the opening is larger than a dime :o
Reply #9March 04, 2013, 04:25:09 pm
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: March 04, 2013, 04:25:09 pm »
WWwhhhaatttt!??!!??!
Reply #10March 05, 2013, 11:17:04 am
« Reply #10 on: March 05, 2013, 11:17:04 am »
intake PORTS**
not the manifold inlet..
Reply #11March 05, 2013, 11:56:12 am
catlin_cava
  • 1954
« Reply #11 on: March 05, 2013, 11:56:12 am »
if the intake itself is the size of a dime the car is always in limp mode and has NO BALLS
Catlin
Reply #12March 05, 2013, 12:08:05 pm
« Reply #12 on: March 05, 2013, 12:08:05 pm »
yup..
Reply #13March 05, 2013, 01:52:16 pm
« Reply #13 on: March 05, 2013, 01:52:16 pm »
I am always amazed when I see this much carbon and resins.
Apparently this car was driving until it was taken apart.
EGR is evil.
Reply #14March 05, 2013, 03:26:23 pm
hillfolk'r
  • 1532
« Reply #14 on: March 05, 2013, 03:26:23 pm »
Theres 2 ways to clean the ports. One at a time or pull the cam. I did the latter because i was already in there doing a belt. Anyways if you do it with the cam in, ya gotta make sure that valve is closed! Then bust out the PROPANE torch. Not an acetylene torch. Burn em out and pick away with screwdrivers and brushes and vacuums and air pressure. If you heat it and blow it out be careful of cinders burning you.
ask me how i know. I cheated, i put in a solid copper egr gasket. Then i cut out a nice little piece of tape for the cel. Stupid computers get it rechipped but i was cheap. Best tdi i had was a M haha no clogging intake crap.
 Subject car was a 98 with like 120k and i couldnt even get my thumb in the main part of the intake. Maybe thats y it hunted and surged at wot over 3k. Ya think?
Throttle cables ftw
