Author Topic: Nuespeed strut tower brace  (Read 9820 times)
Reply #15May 20, 2011, 06:04:02 pm
trav1856
  • 230
Re: Nuespeed strut tower brace
« Reply #15 on: May 20, 2011, 06:04:02 pm »
So would putting on one of those full car prothane kits be worth while as well?
1981 Rabbit Diesel
1981 Cabriolet
Reply #16May 20, 2011, 06:44:29 pm
« Reply #16 on: May 20, 2011, 06:44:29 pm »
Yup, very worth it. My write up on it, http://www.vwdiesel.net/forum/index.php?topic=25324.0
When I fix my rabbits rusty floor I plan to do lots of seam welding to beef things up as much as possible.
Reply #17May 21, 2011, 04:29:58 am
trav1856
  • 230
« Reply #17 on: May 21, 2011, 04:29:58 am »
So if I gather correctly the motor and tranny mounts you should stay away from, but the suspension mounts are good to go?
1981 Rabbit Diesel
1981 Cabriolet
Reply #18May 21, 2011, 07:17:34 am
« Reply #18 on: May 21, 2011, 07:17:34 am »
On the mk1 platform you can get away with Poly in the side mounts, if you leave the front and back rubber. Seeing as how the mk2 doesn't have side mounts.. No luck lol
Reply #19May 21, 2011, 09:31:16 am
« Reply #19 on: May 21, 2011, 09:31:16 am »
I'd just like to point out that comparing generations of the SAME car is like comparing an Apple seed, to an Apple. The next step in the making is OBVIOUSLY going to be better.. I bet you won't guess what out handles the mk2  :o WAIT THE MK3! oh man I didn't see that coming. Yes I have done it, it may be heavier but it handled way better. 98 430000km jetta against a 90 200000km jetta with a fresh suspension.. the 98 had it every-time.
:D :D 8)
But seriously.. I still like my 84 :)
not entirely true.
you'll find that with the exact same suspension set up on similarly powered vehicles that the mk2 will out handle a mk3.
with the suspension geometry being virtually identical, the mk3 only differs to the width of the rear trailing beam and the width of the control arms.
the mk2 handles better in my world. the lightness makes my car more agile.. my GTI will out handle my buddies mk3 jetta any day.. BAD.
ive driven both cars.. the mk2 is STILL my favorite platform. i like mk3 cars, but they just dont have what it takes..
Reply #20May 21, 2011, 01:32:11 pm
trav1856
  • 230
« Reply #20 on: May 21, 2011, 01:32:11 pm »
By side-mounts. You mean the Car's sides? or the Engine's sides?
1981 Rabbit Diesel
1981 Cabriolet
Reply #21May 21, 2011, 02:00:26 pm
« Reply #21 on: May 21, 2011, 02:00:26 pm »
meaning the engine mounts on the left and right side. one on the end of the trans, and one on the front of the engine..
the mk2 has 2 rear mounts, and one front mount.
mk1 has 1 front mount, 2 side mounts, and 1 rear mount..
Reply #22May 23, 2011, 01:38:42 pm
« Reply #22 on: May 23, 2011, 01:38:42 pm »
Are they not one in the same? lol Like timing belt side and transmission side of the mk1 engine configuration.
Reply #23May 23, 2011, 02:12:58 pm
Vangruver
  • 162
« Reply #23 on: May 23, 2011, 02:12:58 pm »
for the front's they are okay, but for the rear they've been known to be poor performing.
My friends get the best street set up with high Density front control arm bushings, which are tougher higher durometer rubber bushings that still provide ample feedback. And front wheel drive Mk2 Audi TT rear control arm bushings.
The Audi bushings are solid rubber, unlike the A2/A3 chassis rear LCA bushings that have air gaps for pivot movements. The combination of those two bushings will provide you a very streetable car with less squeaks and creeks that you'd find in a polyurethane equipped car.
These following links are good reads
http://forums.vwvortex.com/showthread.php?2118568-Why-(Rear)-Poly-Bushings-Are-Bad&highlight=poly+bushings+bad
http://forums.vwvortex.com/showthread.php?4392529-Poly-control-arm-bushings...-good-or-bad&highlight=poly+bushings+bad
To reduce the creeks and squeaks in poly bushings, you'd want to ensure that the sleeve to bushing area is properly lubed otherwise it's annoying as all hell to be in.
Reply #24June 06, 2011, 07:05:25 pm
« Reply #24 on: June 06, 2011, 07:05:25 pm »
Yup, prothanes do squeak a bit.
Reply #25June 06, 2011, 07:09:35 pm
« Reply #25 on: June 06, 2011, 07:09:35 pm »
Never heard mine squeak yet. Only been about 10,000 miles though since they were installed.
Reply #26June 07, 2011, 01:19:49 am
maxfax
  • 2126
« Reply #26 on: June 07, 2011, 01:19:49 am »
Make them greaseable and use synthetic grease......
