Author Topic: Need help with idle  (Read 4993 times)
May 10, 2011, 06:30:16 am
jaysen71581
  • 211
    Hagerstown, MD
Need help with idle
« on: May 10, 2011, 06:30:16 am »
Hey all i finally got around to pulling the car outside and messing with it since its warm out, its hard to start and doesnt sound to healthy idling, here is a video.
Reply #1May 10, 2011, 06:45:40 am
Re: Need help with idle
« Reply #1 on: May 10, 2011, 06:45:40 am »
Sounds like it is only hitting on 2 cyl. I would see what timing value is, condition of injectors, and maybe raise the idle some.
Sounds ok once you pedal it. So maybe not the timing/injectors...but it can't hurt. How long has it ran? Could it be air in the lines?
Reply #2May 10, 2011, 12:03:12 pm
« Reply #2 on: May 10, 2011, 12:03:12 pm »
i would check compression, and raise your idle speed some.. maybe get the injectors pop tested if you can. how long does it do that for? until it warms up, or any time its at idle?
FWIW, that sounds worse than my car starting in 15*f temps, with 2 bad glow plugs, right after being heat seized..  :o
x2 it only sounds like its hitting on 2 cyls when its idling. engine is shaking like its missing too..
Reply #3May 11, 2011, 05:41:46 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #3 on: May 11, 2011, 05:41:46 am »
injectors are good to go they were pop tested about 6 months ago.  how do i check the valve timing?
Reply #4May 11, 2011, 06:16:22 am
nathan_b
  • 361
« Reply #4 on: May 11, 2011, 06:16:22 am »
is your pump 180 out of time?
Reply #5May 11, 2011, 06:50:53 am
« Reply #5 on: May 11, 2011, 06:50:53 am »
Vince Waldon's how to time should be in our FAQ section. DO NOT MESS THE TIMING UP...it will kill your engine.
Another angle, it sounds just like the prothe/hans diesel pump that I had on an N/A. Is it something from him?
Reply #6May 11, 2011, 07:31:27 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #6 on: May 11, 2011, 07:31:27 am »
I was already looking at the Vince writeup, def not a proth pump lol it was a stock TD pump just recently resealed, heres a question, my brother was putting some time in on the motor, its a hydro motor, if he put a cam from a mech head on it would that make it act totally retarded? I always use a socket to lock my pump into place when i change things, ive messed with the belt enough i may just get another belt and swap out belts incase its stretched..
Reply #7May 11, 2011, 08:44:16 am
« Reply #7 on: May 11, 2011, 08:44:16 am »
mech cams are a smaller base circle im pretty sure.. like wouldnt work, or if it did, it would make soo much top end noise you would know it wasnt right..
Reply #8May 13, 2011, 06:57:54 pm
wdkingery
  • 494
« Reply #8 on: May 13, 2011, 06:57:54 pm »
Why did you say bad timin will kill an engine?
Reply #9May 13, 2011, 07:03:59 pm
macka
  • 957
« Reply #9 on: May 13, 2011, 07:03:59 pm »
considering the tolerances if you have the timing out far enough, pistons and valves will meet in the middle and make some nasty noises.
Quote from: Vincent Walden
Reply #10May 13, 2011, 07:36:00 pm
« Reply #10 on: May 13, 2011, 07:36:00 pm »
That sounds like fueling issues to me.
The fact that the engine spins up and spools the turbo, shows me its running ok. If it can do that it should be able to idle just fine. If you sat and let it run like that, what happens? does it just continue or does it smooth out? Was this engine just cold started?
We need quite a bit more information to diagnose over the web.. and through text. ;)
Are your glow-plugs all working correctly? I've had this exact problem on a few diesels na or td.. its been air in the lines/pump.
Reply #11May 13, 2011, 07:44:34 pm
truckinwagen
  • 1895
« Reply #11 on: May 13, 2011, 07:44:34 pm »
mech cams have a larger base circle due to the lifters being thinner.
what RPM is it idling at? try kicking the speed up a bit and see where that gets you
83 Opel Kadett Diesel
Reply #12May 13, 2011, 07:52:33 pm
« Reply #12 on: May 13, 2011, 07:52:33 pm »
I dunno, I've turned my idle down so far (for ***s and giggles) that the alt lamp was flickering, and so was the oil buzzer..
and it was running just fine.
Reply #13May 14, 2011, 09:46:06 am
« Reply #13 on: May 14, 2011, 09:46:06 am »
i knew one of the cams had a bigger base circle.. thanks for clearing that up!
Reply #14May 18, 2011, 05:41:22 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #14 on: May 18, 2011, 05:41:22 am »
After finally getting a alittle time to work on the car i switched the original cam in the head followed Vince's timing guide and messed with my pump timing and these are my results
