Author Topic: 2004 Audi S4 service  (Read 6554 times)
May 04, 2011, 08:15:37 pm
Powered by Spearco
  • 1203
« on: May 04, 2011, 08:15:37 pm »
We got in a nice '04 S4 in for some service work. Thought that I'd post some pics of the work involved.
Intake manifold was leaking, causing misfires and lean fuel trims. So R&R intake.
Valve covers were leaking oil on exhaust and down the front of engine. R&R valve cover gaskets.
Engine oil cooler/heat exchanger was leaking extrernaly. This was a good one to get to.
It lived here.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #1May 04, 2011, 08:27:32 pm
Powered by Spearco
  • 1203
Re: 2004 Audi S4 service
« Reply #1 on: May 04, 2011, 08:27:32 pm »
Had to remove the water cooled Alt. to get to the cooler.
Also AC compressor is inop. Oh boy! No to mention, its shaft driven off the back of the engines timing chains.
'13 Golf R:. Tuned
'98 Puch G320
Reply #2May 04, 2011, 09:53:53 pm
Quantum TD
  • 1195
« Reply #2 on: May 04, 2011, 09:53:53 pm »
I always wanted an Audi Allroad (same motor). I just changed my mind.
Well, maybe get the shell, sell the motor, and drop in a 2.0 BEW.Those BiTurbo motors EAT fuel.
Reply #3May 04, 2011, 10:04:14 pm
Powered by Spearco
  • 1203
« Reply #3 on: May 04, 2011, 10:04:14 pm »
I'd rather work on these any day compaired to the A6/Allroad POS's  ;D. This is the 4.2 V8. I love the 2.7T engines but the bodys suck.
You said 2.0L BEW? Do you mean BHW? Passat.
'13 Golf R:. Tuned
'98 Puch G320
Reply #4May 04, 2011, 10:56:31 pm
mystery3
  • 774
« Reply #4 on: May 04, 2011, 10:56:31 pm »
I love the s4 avants but I cannot afford the maintenance on one of those badboys. My wrx is bad enough.
Reply #5May 05, 2011, 06:35:16 am
rallydiesel
  • 1880
« Reply #5 on: May 05, 2011, 06:35:16 am »
Is it normal for the valve lobes to look like that? They look pretty crappy but I don't have any experience with roller cams.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6May 05, 2011, 10:12:49 am
« Reply #6 on: May 05, 2011, 10:12:49 am »
I love my rabbit even more now!!!!!!!
Reply #7May 05, 2011, 10:32:37 am
« Reply #7 on: May 05, 2011, 10:32:37 am »
That's a V8 S4, not a 2.7TT.
That one looks neglected.....   :o
They actually aren't that bad to work on compared to what they could be.
Reply #8May 05, 2011, 02:19:34 pm
« Reply #8 on: May 05, 2011, 02:19:34 pm »
yea, thats how roller cams look once they been used for a while..
Reply #9May 06, 2011, 09:36:58 pm
Powered by Spearco
  • 1203
« Reply #9 on: May 06, 2011, 09:36:58 pm »
Sorry, no together pics, but its all back together.
AC blows ice cold, fuel trims are at 1.2 and -.9 for banks 1 and 2 for idle and trims for part throttle are at 1.3 and 1.1. Plus no more oil leaks.
The scary thing when putting back together was that once I hooked up the Rad. lines and pressure tested the cooling system, there was a leak at the Alt. fittings at the hard line connections. If you look back at the pics, I never touched them but luckly everything, the front end, was partialy disconnected. So getting to the hold down bolt and O-rings wasn't to bad. Replace them, refastened the hoses and repressure tested and all was fine. Wew.
Fun car. Not as fast as I thought it would be though. But still, its an S4.
'13 Golf R:. Tuned
'98 Puch G320
Reply #10May 06, 2011, 10:25:41 pm
Quantum TD
  • 1195
« Reply #10 on: May 06, 2011, 10:25:41 pm »
Oh, that's the part I LOVE! I dig the aggressive wheels and the cladding on the lower rockers.  Tits.
That's what I meant. Balance shaft problems and all, I'd take one over the 2.7 Biturbo or 4.2 any day.
Reply #11May 08, 2011, 12:29:08 am
79rabbit4dr
« Reply #11 on: May 08, 2011, 12:29:08 am »
I just got rid of my '01 allroad. Loved it! I'd have another one but the 6 speed this time. Or I'd take an RS6  ;D
