General Information
Troubleshooting
vanagon aaz windage tray
Topic: vanagon aaz windage tray (Read 4418 times)
May 04, 2011, 12:10:38 pm
paolomarks
May 04, 2011, 12:10:38 pm »
So I'm putting an AAZ into my Vanagon 81 diesel. Should I use the stock AAZ windage tray even though it's now at 40 degrees? Also the AAZ gasket incorporates "spacers" which make it thicker than the 1.6's. Will I have trouble lining up oil pan to tranny bolt holes with this configuration? What do you all think? Thanks, Paolo.
May 04, 2011, 06:07:00 pm
Syncroincity
Re: vanagon aaz windage tray
May 04, 2011, 06:07:00 pm »
No difference in the holes lining up.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
May 04, 2011, 06:20:46 pm
May 04, 2011, 06:20:46 pm »
I know some people say it's tight to get the bolts in that run through the transmission, but i had no problem
May 04, 2011, 06:30:11 pm
paolomarks
May 04, 2011, 06:30:11 pm »
Thanks for the prompt replies. The rubber gasket ripped a bit in a few places when it was removed, can I use some sealer like RTV or should I get a new one. Paolo
May 04, 2011, 10:00:54 pm
nathan_b
May 04, 2011, 10:00:54 pm »
Get a new one and use some sealer
General Information
Troubleshooting
