Author Topic: vanagon aaz windage tray  (Read 4498 times)
May 04, 2011, 12:10:38 pm
paolomarks
  • 146
« on: May 04, 2011, 12:10:38 pm »
So I'm putting an AAZ into my Vanagon 81 diesel.  Should I use the stock AAZ windage tray even though it's now at 40 degrees?  Also the AAZ gasket incorporates "spacers" which make it thicker than the 1.6's.   Will I have trouble lining up oil pan to tranny bolt holes with this configuration?  What do you all think?  Thanks, Paolo.
Reply #1May 04, 2011, 06:07:00 pm
Syncroincity
  • 727
Re: vanagon aaz windage tray
« Reply #1 on: May 04, 2011, 06:07:00 pm »
No difference in the holes lining up. :)
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #2May 04, 2011, 06:20:46 pm
  • 1739
« Reply #2 on: May 04, 2011, 06:20:46 pm »
I know some people say it's tight to get the bolts in that run through the transmission, but i had no problem
Reply #3May 04, 2011, 06:30:11 pm
paolomarks
  • 146
« Reply #3 on: May 04, 2011, 06:30:11 pm »
Thanks for the prompt replies.  The rubber gasket ripped a bit in a few places when it was removed, can I use some sealer like RTV or should I get a new one.    Paolo
Reply #4May 04, 2011, 10:00:54 pm
nathan_b
  • 361
« Reply #4 on: May 04, 2011, 10:00:54 pm »
Get a new one and use some sealer 8)
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
