Author Topic: Where do these wires go?  (Read 4396 times)
April 08, 2011, 01:48:26 pm
gnavs
  • 340
« on: April 08, 2011, 01:48:26 pm »
As stated.  I want to just ground them but the insulation isn't green which has me hesitating.  Does anyone know where they're supposed to go?  This is on a MK3 AAZ.
Thanks.
Reply #1April 08, 2011, 01:54:20 pm
rodpaslow
  • 670
Re: Where do these wires go?
« Reply #1 on: April 08, 2011, 01:54:20 pm »
By my experience any brown wire in A2 & A3 cars (generally) are ground.  I have no experience with AAZ though.
It looks to me like they connected to the water outlet at the side of the head so I'd be 90% sure they are ground.  Easy to test - connect a test light to pos on battery and touch each of them - this MAY help tell if they should be ground or not...
Reply #2April 08, 2011, 02:10:56 pm
« Reply #2 on: April 08, 2011, 02:10:56 pm »
Yup... they generally attach to the coolant outlet flange via a double nut.
Reply #3April 08, 2011, 02:12:31 pm
gnavs
  • 340
« Reply #3 on: April 08, 2011, 02:12:31 pm »
thanks fellas, should be starting the thing up this weekend if all goes well.  I'll make sure to post pics/videos.
Reply #4April 09, 2011, 02:43:05 pm
Vitwagen
  • 68
« Reply #4 on: April 09, 2011, 02:43:05 pm »
Er, are those are on the engine side of the standard electrical plug, red with a white stripe?
If so, they're the glowplug feed. Both go to the nearest glowplug (gearbox end). I've had 2 UK AAZs, both were like this (and the wires looked identical to you pic).
HTH
Reply #5April 09, 2011, 03:52:12 pm
« Reply #5 on: April 09, 2011, 03:52:12 pm »
HTH
the glow plug feed wires are much larger gauge than those wires are..
Reply #6April 09, 2011, 09:08:39 pm
« Reply #6 on: April 09, 2011, 09:08:39 pm »
Why does your AAZ valve cover have studs around the edge?
Reply #7April 09, 2011, 09:10:26 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: April 09, 2011, 09:10:26 pm »
This.
Reply #8April 10, 2011, 07:10:33 am
« Reply #8 on: April 10, 2011, 07:10:33 am »
Well, now that I look at it again the colour is a bit unclear in the picture... at least for my feeble eyes.
If they be truely brown, they should be grounds.
If red with a white stripe, they should be the double wires used to provide power to the glow plug buss... the AAZ uses a couple of small wires in parallel rather than a single heavy wire like the 1.6, since the wires have to pass thru the pins of the big engine connector.
Oh, and Ive guessing the OP has a G60 aluminum valve cover that he's bolted down around the perimeter.
"CSI: Diesel Engines" is my favorite show.  ;)
Reply #9April 10, 2011, 12:49:57 pm
Vitwagen
  • 68
« Reply #9 on: April 10, 2011, 12:49:57 pm »
HTH
Nope, not on the 2 factory AAZs I've seen. if you follow the wiring through the plug, the 2 wires join into one larger gauge wire (also red with white stripe).
Reply #10April 10, 2011, 02:24:41 pm
« Reply #10 on: April 10, 2011, 02:24:41 pm »
HTH
sorry, they looked brown to me..
im not used to seeing 2 glow plug wires on a 4 banger, only cars ive seen that setup on, are the 5 banger diesels..
Reply #11April 11, 2011, 02:13:56 pm
gnavs
  • 340
« Reply #11 on: April 11, 2011, 02:13:56 pm »
As Vince stated, I modified the head to fit the G60 valve cover.
Thanks for the help guys.  Can I safely delete these wires if I'm using Vince's pimped glowplug system?  I'm thinking of bypassing the system entirely and running the glowplugs with a momentary switch mounted in the cabin.
Reply #12April 11, 2011, 02:37:26 pm
« Reply #12 on: April 11, 2011, 02:37:26 pm »
Yup... you'll provide your own heavy-duty power feed to the glowplugs from the extra solenoid.
You can drive the extra soleniod from the original output of the glowplug fuse bolted to the firewall, or use a manual pushbutton as you mention.  If you pull the glow plug fuse you've disconnected those two wires in your picture and you can tape-em-and-forget-em.
Reply #13April 13, 2011, 02:27:44 pm
gnavs
  • 340
« Reply #13 on: April 13, 2011, 02:27:44 pm »
Awesome, thanks Vince
