Author Topic: AAZ passat transmission question  (Read 4766 times)
April 06, 2011, 02:02:32 pm
ilikevwdiesel
  • 1202
« on: April 06, 2011, 02:02:32 pm »
anyone know what code transmission was installed on AAZ passats? models with the eco engine.
thanks
My Bio
Reply #1April 07, 2011, 07:24:10 pm
ein bora
  • 377
Re: AAZ passat transmission question
« Reply #1 on: April 07, 2011, 07:24:10 pm »
Code CHD = ratio - 3.45, 1.94, 1.29, 0.91, 0.75. final drive - 3.67
I have one if you are looking to buy one.
If you can't take advice - then you can't be helped!
Reply #2April 07, 2011, 07:49:11 pm
ilikevwdiesel
  • 1202
« Reply #2 on: April 07, 2011, 07:49:11 pm »
that's a cable clutch trans aren't all the passats hydraulic clutch?
My Bio
Reply #3April 07, 2011, 09:05:22 pm
« Reply #3 on: April 07, 2011, 09:05:22 pm »
didnt the passat get an 02A?
Reply #4April 08, 2011, 12:20:04 am
MJF
  • 581
« Reply #4 on: April 08, 2011, 12:20:04 am »
Yep.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5April 08, 2011, 11:11:14 pm
neimis
  • 75
« Reply #5 on: April 08, 2011, 11:11:14 pm »
My 1992 Canadian TD Passat has a 02A, code CEY. It is very difficult to find information about this transmission; essentially these were cars built for the European market but brought over to Canada. I had to figure out the ratios with the help of my parts guy and the European ETKA
Canadian Passat TD AAZ 1991 - 92
02A ratio:
CEY====3.778=2.118=1.345=0.917=0.717=3.944==Passat AAZ
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #6July 06, 2012, 10:00:33 am
rodpaslow
  • 670
« Reply #6 on: July 06, 2012, 10:00:33 am »
Where does a person find the code for 02A?  I've searched forum and trans -a all I can find it the 02a.
Reply #7July 06, 2012, 10:04:28 am
« Reply #7 on: July 06, 2012, 10:04:28 am »
between shift tower and bellhousing..
fyi there is a cable set up for the 02a.. and i think passats had cab;es..
Reply #8July 06, 2012, 11:03:22 am
rodpaslow
  • 670
« Reply #8 on: July 06, 2012, 11:03:22 am »
Yeah the one I have is off of a 93 passat and it has cable shift.  I have a 96 car I want to put it in, 1.6 td.  I'd just like to know the gearing if I'm going to have to look for better 5th or if it's good as is; or at least comparable to the 020 that's in it right now.
Reply #9July 06, 2012, 01:46:58 pm
carrizog60
  • 978
« Reply #9 on: July 06, 2012, 01:46:58 pm »
mine had a cable from stock,but cant remenber the code right now.ecodiesel passat from germany,1994 but still a 35i model.
it was short geared,lack of rev counter wont get me be accurate but i gess it was in the middle of a 4s and 4t.
too short so changed to a tdi gearbox,as the passat had all the stuff needed to a drop in conversion.
Portugal
Reply #10July 06, 2012, 03:42:04 pm
« Reply #10 on: July 06, 2012, 03:42:04 pm »
I think some of the Passat AAZs had a CHA in them
http://zelek.com/diagram_charts/diagramlist.htm
Reply #11July 08, 2012, 07:48:44 am
CrazyAndy
  • 739
« Reply #11 on: July 08, 2012, 07:48:44 am »
Either that or the CTN/CHU maybe, because the Zelek list says "1.9L" and not just "TDI".
Reply #12July 08, 2012, 08:21:39 am
« Reply #12 on: July 08, 2012, 08:21:39 am »
I'm pretty sure that CTN is only a TDI tranny found on the AHU/1Z TDIs
Reply #13July 08, 2012, 02:27:21 pm
carrizog60
  • 978
« Reply #13 on: July 08, 2012, 02:27:21 pm »
ecodiesel was short geared,not tdi long ratios...
Portugal
Reply #14July 08, 2012, 02:58:55 pm
« Reply #14 on: July 08, 2012, 02:58:55 pm »
CTN was a 98 TDI tranny. I have one in my garage, some day it will make it under the hood of my 84 :).
