Author Topic: Northwest All Out Soot Out..  (Read 45136 times)
Reply #15April 10, 2011, 10:01:17 am
Powered by Spearco
  • 1203
Re: Northwest All Out Soot Out..
« Reply #15 on: April 10, 2011, 10:01:17 am »
For spooling the turbo off the line and to helping to burn the lost HP out the tail pipe at 5K RPM
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #16April 10, 2011, 10:04:49 am
Powered by Spearco
  • 1203
« Reply #16 on: April 10, 2011, 10:04:49 am »
By the way, I did relocate the LDA ref. to the compressor outlet instead of the intake. Not to noticeable on my build.
'13 Golf R:. Tuned
'98 Puch G320
Reply #17April 10, 2011, 10:09:54 am
« Reply #17 on: April 10, 2011, 10:09:54 am »
i wasnt sure if it would be noticeable or not. just that you may see SLIGHTLY higher pressures there, so the LDA might come on a half second sooner.
i think the nitrous bottle is gonna get filled up on monday.. then i will have to fill it up again before the soot out im sure..
god, you can burn thru a tank of NOS quick..
i dont have to worry about blowing the head off my block do i? nitrous is tame on diesels isnt it? (my head is still held down with bolts)
Reply #18April 10, 2011, 10:19:18 am
Powered by Spearco
  • 1203
« Reply #18 on: April 10, 2011, 10:19:18 am »
Blow through a bottle. What are you doing? Full throttle NOS pulls for every light and shift  :D.
I can only quess is thats its fun, other wise you wouldn't do it, huh?
You can still do damage, only to the head gasket? What do you exspect for stock bolts, head gasket and what not. It would be cool to se if it did blow off at the dyno though  ;D.
'13 Golf R:. Tuned
'98 Puch G320
Reply #19April 10, 2011, 11:34:37 am
« Reply #19 on: April 10, 2011, 11:34:37 am »
one problem i just thought about while eating breakfast.. idk WTF im gonna do if it breaks. i dont have a way to tow the car back home. or get myself home for that matter..
(i may just buy some head studs between now and then, im still running an 11mm block, if the head lifts, my block is toast)
Reply #20April 10, 2011, 11:47:50 am
Powered by Spearco
  • 1203
« Reply #20 on: April 10, 2011, 11:47:50 am »
Better bring a spare eng. just in case  :-\ ;).
'13 Golf R:. Tuned
'98 Puch G320
Reply #21April 10, 2011, 11:53:59 am
« Reply #21 on: April 10, 2011, 11:53:59 am »
sad thing is, im serious. and now im debating even running, just because im the person that usually has bad luck, if there is bad luck to be found..
Reply #22April 10, 2011, 01:06:13 pm
81 vw pu
« Reply #22 on: April 10, 2011, 01:06:13 pm »
Hey guys, don't worry about making a mess on the dyno, they just oiled down our drag strip yesterday with a talon. Still clicked off a 9.40 though.
Just kidding, hope no one toast their engine. That is a big concern for me if I make the trip, whether to drive the caddy or load it my ramp truck.
I think nitrous on the dyno would work better than a air to air intercooler since there's no airflow through the intercooler to remove heat.
Reply #23April 10, 2011, 02:21:38 pm
« Reply #23 on: April 10, 2011, 02:21:38 pm »
i was thinking about taking my intercooler out, and running just nitrous as my intercooler..
wheres the best place to shoot it? right before the turbo, or right before the intake plenum?
i run a gasser intake mani, i was thinking about putting the nozzle in the adapter i made for the plenum. (the adapter that the boost hoses hook up to)
i just wanna make sure im not gonna kill my engine cause i shot the nos at the wrong spot in the intake..
Reply #24April 10, 2011, 05:21:43 pm
81 vw pu
« Reply #24 on: April 10, 2011, 05:21:43 pm »
I have my nitrous nozzle in the intake so it doesn't absorb heat from the turbo and piping.
I don't think you will kill your engine from injecting it in a different place though.
The only thing I see killing a headgasket is alot of fuel and alot of nitrous with high boost =  high cylinder pressure.
I've had good luck so far with my worn out  turboed 1.6na and am up to a 50 shot with no leaks yet.
Nitrous contains something like 30 percent more oxygen than air, so maybe back down the boost some to be on the safe side.
I only run about 12-15 psi boost on nitrous with a stock gasket and headbolts.
Reply #25April 10, 2011, 07:01:02 pm
Powered by Spearco
  • 1203
« Reply #25 on: April 10, 2011, 07:01:02 pm »
I was planning on mounting mine here.
I think it might be far enough back to flow evenly into the plenum.
Also mounted the the full throttle switch.
http://s232.photobucket.com/albums/ee10/joshmarstall/?action=view&current=VID00030-20110409-1619.mp4
« Last Edit: April 10, 2011, 07:03:14 pm by Powered by Spearco »
'13 Golf R:. Tuned
'98 Puch G320
Reply #26April 10, 2011, 08:10:23 pm
Powered by Spearco
  • 1203
« Reply #26 on: April 10, 2011, 08:10:23 pm »
81 vw pu, you got any pics of your install?
'13 Golf R:. Tuned
'98 Puch G320
Reply #27April 10, 2011, 08:30:55 pm
81 vw pu
« Reply #27 on: April 10, 2011, 08:30:55 pm »
Looks good Josh, If your nozzle location doesn't flow evenly mine sure as hell won't.
Those nozzles have a fan type exit that should disperse the nitrous pretty well if you line up the dimple
on the nozzle with the direction you want the nitrous to spray.
Here's the intake I got from you awhile back and where I put my nozzle (not many options in my setup).
Reply #28April 10, 2011, 08:40:54 pm
Powered by Spearco
  • 1203
« Reply #28 on: April 10, 2011, 08:40:54 pm »
Wait, yours is right on top of the manifold. Wheres your tip pointing? If its pointing to the manifold, won't it spry inaccurate?
Where did you mount the solenoid?
I'm thinking here for mine.
I just ordered a NOS manifold to be able to feed two solenoids.
'13 Golf R:. Tuned
'98 Puch G320
Reply #29April 10, 2011, 08:54:34 pm
Powered by Spearco
  • 1203
« Reply #29 on: April 10, 2011, 08:54:34 pm »
I just figured out a cheaper way to "T" the feed lines to solenoids, for $3.60, instead of the $40+ for the stupid manifold  >:( ::). Oh well. Still need extra lines and 4an fittings, so still not done.
'13 Golf R:. Tuned
'98 Puch G320
