Author Topic: bosio nozzles for AAZ injectors  (Read 10104 times)
March 31, 2011, 04:44:02 pm
ilikevwdiesel
  • 1202
« on: March 31, 2011, 04:44:02 pm »
kerma tdi lists nozzles for canadian AAZ engines, no. 308. I called the guy and he doesn't know if they fit the two stage injectors. Does anyone know wether or not they do or another source for new AAZ injector nozzles? Giles sez bosch doesn't offer them so he doesn't either  :(
My Bio
Reply #1March 31, 2011, 04:54:37 pm
Re: bosio nozzles for AAZ injectors
« Reply #1 on: March 31, 2011, 04:54:37 pm »
Can you link to the nozzles they are talking about... I can't find 'em on their site.??
Here's another option for new nozzles that will fit the AAZ injector bodies:
http://www.veg-injection-service.com/store/index.php?main_page=product_info&products_id=18
You'll want 'em properly calibrated... and it's a job beyond the standard home-made pop-tester.  Giles can do it if you can't find anyone closer.
Reply #2March 31, 2011, 04:58:07 pm
ilikevwdiesel
  • 1202
« Reply #2 on: March 31, 2011, 04:58:07 pm »
http://www.kermatdi.com/servlet/-strse-21/Bosio-VW-GTD-Nozzles/Detail
those nozzles.
the veg gtd nozzles fit the dual stage injectors huh?
My Bio
Reply #3March 31, 2011, 05:01:51 pm
« Reply #3 on: March 31, 2011, 05:01:51 pm »
As far as I can tell those are the same nozzles (so-called "GTD" or "308s")... just a different price.   ;)
And yup, the KCA-style nozzles are all the same dimensionally... GM/Mercedes/VW.
Reply #4March 31, 2011, 05:04:32 pm
ilikevwdiesel
  • 1202
« Reply #4 on: March 31, 2011, 05:04:32 pm »
I'm just weirded out by the AAZ injector thing cause I have an AAZ here from a passat and it has the regular single stage injectors but the jetta engine in my caddy has the dual stage. anyone ever actually swap the nozzles from one style to the other?
My Bio
Reply #5March 31, 2011, 05:05:54 pm
« Reply #5 on: March 31, 2011, 05:05:54 pm »
Yup...I have.  The dual stage injector bodies are slightly taller to accommodate the extra shims and springs but at the bottom where the nozzle installs they are the same and will handle any IDI KCA-style nozzle you want to install.
Reply #6March 31, 2011, 05:12:50 pm
ilikevwdiesel
  • 1202
« Reply #6 on: March 31, 2011, 05:12:50 pm »
ok well that's interesting. I wonder why giles won't put nozzles in from the other injectors? Monark is another brand I wonder what they have to say about this topic...
My Bio
Reply #7March 31, 2011, 09:23:40 pm
neimis
  • 75
« Reply #7 on: March 31, 2011, 09:23:40 pm »
Just a tip - keep in mind that if you are replacing your single stage injectors with the two stage ones, you will need different hard fuel lines because of the extra height of the two stage injectors. Also, if you are installing them yourself, first make sure that you can find a socket that will be deep enough to work on them - this can be difficult to do! They need a deeper socket than single stage injectors.
As a side note, I replaced my single stage injectors a couple of years ago with two stage ones (I had Giles install and balance some new "GTD" nozzles in the two stage bodies). To be honest, I really didn't notice much or any difference.
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #8March 31, 2011, 10:25:22 pm
zagarus
  • 619
« Reply #8 on: March 31, 2011, 10:25:22 pm »
i just got a set of those 308 nozzles and sent them to giles with my aaz injectors. no issues.
Reply #9March 31, 2011, 10:32:13 pm
Powered by Spearco
  • 1203
« Reply #9 on: March 31, 2011, 10:32:13 pm »
I was told by Giles that the dual spring injector need different delivery valves and that they need to be calabrated too for the AAZ ones.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10April 15, 2011, 11:05:50 am
blackbird82
  • 151
« Reply #10 on: April 15, 2011, 11:05:50 am »
Is that true?
Hmm I got a 94 Jetta, and its an AAZ that orignially had single spring injectors
i swapped to dual sping, same lines! haha
it fit!
But I have been thrinking about getting the pump done
I have another AAZ motor, complete.
It has a pump and dual spring injectors from day one
never heard it run.
been thinkin about tearin it down.
can a  AAZ pump that ran single's be made to run dual springs easily?
I looked under the bosch parts books for VE pumps and the camplate is the same listed for all AAZ's
I love the whistle......
