Author Topic: OK Gurus, before I start to tear into it  (Read 9528 times)
March 28, 2011, 12:59:04 pm
motomike33y
  • 190
« on: March 28, 2011, 12:59:04 pm »
Driving down the freeway at 65 mph in rab-jetta when noise like belt breaking/being shredded is heard, so I throw in clutch, engine dies, and I coast a mile to my exit, get around corner and pull off.  Look under hood, and timing belt(and everything else) still there.  So I turn it over, and it starts, smoking grey smoke heavily, but I'm only a mile from house so I ease along in third on fairly level road, car missing but pulling me along.  Put in the clutch once and it wants to rev wide-open so I let the clutch back out and lug along to my driveway.  It stops partway up in the snow, so I let it sit.  Get the snowblower and clean out driveway, and try to start it, but it doesn't want to turn(may be battery because fanbelt was loose per alternator charging at8-10 volts(was going to check it out on the weekend, etc.)  towed it up the drive and parked it for couple days.  got wrench and turned it over w/no obvious noises, tried starter again and it rolled, but then battery too low I think.  Will charge it this weekend.  Prior to noise on freeway, both temp and oil pressure gauges acting normal-running at about 80 degrees Celsius and 4 bars plus oil pressure.  checked dipstick, and it seems to be high.  didn't have time last weekend to do much as I was working on all the other family vehicles.  Let's hear some thoughts about what may have happened, or what you think I should check first, and we'll see if anybody is correct.  thanks.
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1March 28, 2011, 01:33:37 pm
Re: OK Gurus, before I start to tear into it
« Reply #1 on: March 28, 2011, 01:33:37 pm »
If the alternator isn't turning, neither is the water pump, and you can hang a piston without the gauge getting very high.
Hope you are luckier than me.
Reply #2March 28, 2011, 03:11:10 pm
motomike33y
  • 190
« Reply #2 on: March 28, 2011, 03:11:10 pm »
alternator belt was turning,but was wet from roadway and not running alternator well, waterpump was keeping engine around 80 C. even with cover over the front of the radiator
2012 golf tdi
Reply #3March 28, 2011, 05:37:33 pm
  • 1739
« Reply #3 on: March 28, 2011, 05:37:33 pm »
Was your timing belt so loose it jumped ?
Reply #4March 28, 2011, 07:01:04 pm
motomike33y
  • 190
« Reply #4 on: March 28, 2011, 07:01:04 pm »
I haven't taken the cover off to check yet, but it hadn't been, and I'd only put about 500 miles or less since putting things back together.  I was cruising along w/out any sudden stress that might have caused it to jump
2012 golf tdi
Reply #5March 28, 2011, 09:01:35 pm
nathan_b
  • 361
« Reply #5 on: March 28, 2011, 09:01:35 pm »
cam gear tight?
Reply #6March 28, 2011, 09:03:25 pm
« Reply #6 on: March 28, 2011, 09:03:25 pm »
where did you get your IP done?
Reply #7March 29, 2011, 07:21:24 am
motomike33y
  • 190
« Reply #7 on: March 29, 2011, 07:21:24 am »
same IP that I had been running last year on the original jetta motor.  nothing done to it-was from this rabbit engine originally.
2012 golf tdi
Reply #8March 30, 2011, 01:52:22 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #8 on: March 30, 2011, 01:52:22 pm »
I had something very similar happen to me once..... One of the bolts for that little bracket inside the timing belt cover fell out and got into the timing belt..... Fortunately it just threw the IP off and the cam and crank stayed in time, so I wasn't banging valves into pistons at least. The symptoms sound very similar, belched alot of white smoke and had no power, I didn't have the high rev thing though. I was about 50 miles from home but luckily a guy I knew happened to come by and he towed me home.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #9March 31, 2011, 08:18:53 am
motomike33y
  • 190
« Reply #9 on: March 31, 2011, 08:18:53 am »
now that sounds intriguing-will check that out this weekend also
2012 golf tdi
Reply #10March 31, 2011, 06:23:12 pm
motomike33y
  • 190
« Reply #10 on: March 31, 2011, 06:23:12 pm »
more clues.  took the guard off the timing belt, everything looked ok.   decided to take the valve cover off, so removed the air cleaner cover.  discovered oil lying in the manifold along w/some greenish liquid that looked like antifreeze.  appeared to have some oil in the air cleaner.checked the antifreeze reservoir-nothing in it.  checked the oil level again-about 2 inches too high.  some odor of burnt oil-not milky color, but dark black.  removed the injectors and looks like some liquid visible down in the area below the gp tips.  didn't try to turn it over as I'm afraid I have liquid in the cylinder and want to check it out a little more first.  removal of injectors should avoid compression lockup, but I'd like to drain fluid from oil pan.  suspect I have a blown head gasket that allowed antifreeze into the oil, and was burning that combo.  revving caused by excess oil in intake.  will check it more this weekend.
2012 golf tdi
Reply #11March 31, 2011, 11:05:01 pm
Toby
  • 728
« Reply #11 on: March 31, 2011, 11:05:01 pm »
No matter what the gauge said it is likely that you cooked the motor. It was likely running away on its own blowby.
Reply #12April 01, 2011, 08:39:42 am
« Reply #12 on: April 01, 2011, 08:39:42 am »
you can hang a piston and not have the gauge move at all.. ive done it. somehow i got lucky and the engine did not die (IDK how tho!)
but if the water pump isnt pumping enough/at all, you will notice it on the gauge rather quickly.
and usually the alternator belt takes ALOT of water to make it slip.. i have to splash thru a decent puddle to get my belt squealing, AND i live on the oregon coast.. i know what rain is.. lol.
Reply #13April 01, 2011, 10:28:28 am
motomike33y
  • 190
« Reply #13 on: April 01, 2011, 10:28:28 am »
After I drain the oil pan, I'll check the compression to compare to my tests in January.  then I'll take the pipe and head off and see how much is wrong. I'm assuming at least one will be low but the compression test will help give me more info.  I had been losing some antifreeze, but hadn't driven very far before this incident so I don't think engine is toast but....we'll see what I find, and I'll keep the post updated.
2012 golf tdi
Reply #14April 10, 2011, 05:54:05 pm
motomike33y
  • 190
« Reply #14 on: April 10, 2011, 05:54:05 pm »
no snow this weekend so I could work.  Compression was 0, 800, 650, 450 psi.  Took the head off and there was a valve missing on #1  cylinder.  Looked into the cylinder-no piston-and the bottom of the connecting rod is looking up at me.  also small hole towards bottom of cylinder where something went elsewhere.  didn't bother to take oil pan off. Both head and block bad, so not the simple fix I thought.  Time to scrap this project.  Maybe I'll get a newer engine in the distant future unless someone wants a clean 91 jetta shell.
2012 golf tdi
