i believe the stem length is different on those
pretty sure its not, however it may be different.
Stock 1.6D valves are 34mm intake and 31mm exhaust with 8mm stems.
This is 100% correct. The diesel valves are ~105mm in length. The gasser valves are ~91mm in length. Part of this has to do with the head of the diesel being flat, so the valve has to be longer. On the gas engines, with part of the combustion chamber in the head, they're shorter.
also solid lifter and hydro lifter have different length valves
