Author Topic: How much boost with gov mod  (Read 3850 times)
March 21, 2011, 07:23:28 am
Fredrikkk
  • 155
« on: March 21, 2011, 07:23:28 am »
How much boost do I have to run to not have any black smoke with this mod? I'm running 1.05 bar with my K14 right now. Is that enough? :)
1991 VW Golf Pasadena GTD - Yeah, it's awesome.
Reply #1March 21, 2011, 08:47:09 am
Re: How much boost with gov mod
« Reply #1 on: March 21, 2011, 08:47:09 am »
governor mod has nothing to do with where your max fuel screw is..
either turn your max fuel down till the smoke stops, or up the boost till it doesnt smoke, or something breaks..
Reply #2March 21, 2011, 09:43:24 am
Fredrikkk
  • 155
« Reply #2 on: March 21, 2011, 09:43:24 am »
It increases fueling though right? So I'll have more fuel than I have now.
Reply #3March 21, 2011, 09:49:38 am
« Reply #3 on: March 21, 2011, 09:49:38 am »
it gives more fuel in the upper RPM range.. not just more fuel period..
it basically moves your governor from 4800, to 5600..
normally, a governor will start cutting fuel at 4000rpms, or even before..
and with a governor mod, it provides full fueling till it cant turn anymore rpms..
the fuel screw is what determines the amount of fuel being injected..
Reply #4March 21, 2011, 10:03:05 am
Fredrikkk
  • 155
« Reply #4 on: March 21, 2011, 10:03:05 am »
I understand.
Thanks!
Reply #5March 21, 2011, 08:00:36 pm
« Reply #5 on: March 21, 2011, 08:00:36 pm »
If you haven't already check out the link in my signature.
Doing the governor mod will take the governor (thats starts cutting fuel as low as 2800) and basically remove its function. So the limiting factor is the rollers in the pump not having enough spring pressure to push them back on the camplate.
You will probably find even if the smoke screw is at the stock spot, you might have to back it OUT after doing the Gov Mod.
Reply #6March 22, 2011, 12:28:27 am
Fredrikkk
  • 155
« Reply #6 on: March 22, 2011, 12:28:27 am »
Yeah that's what I thought I initially.
I've read through your gov mod thread and it's really good :) I'm gonna buy myself a used pump to practice on first though.
To do the job here in Norway the local mechanic wants 2-3000 dollars...
Reply #7March 22, 2011, 06:52:36 am
macka
  • 957
« Reply #7 on: March 22, 2011, 06:52:36 am »
holy crap
Quote from: Vincent Walden
Reply #8March 22, 2011, 07:55:19 am
Fredrikkk
  • 155
« Reply #8 on: March 22, 2011, 07:55:19 am »
Yup.. It's crazy.
He said that as a shop owner he didn't want the responsibility of doing the mod.
Reply #9March 22, 2011, 07:58:21 am
macka
  • 957
« Reply #9 on: March 22, 2011, 07:58:21 am »
Yup.. It's crazy.
so he prices himself out of the job. Geez it would have been about 500 bucks cheaper on the low side of the price to get a Giles pump and just install it.
Reply #10March 22, 2011, 08:17:21 am
Fredrikkk
  • 155
« Reply #10 on: March 22, 2011, 08:17:21 am »
That's so very true! You just gave me an idea ;)
Maybe I'll buy a pump from him?
Reply #11March 22, 2011, 08:32:22 am
macka
  • 957
« Reply #11 on: March 22, 2011, 08:32:22 am »
That's what my plan is. Much easier to pay to have it done right, and drop it in. I don't do pump voodoo, but I know how to build engines.
Reply #12March 22, 2011, 08:36:31 am
Fredrikkk
  • 155
« Reply #12 on: March 22, 2011, 08:36:31 am »
I could time my engine myself by just getting a dial gauge. And change the HG and timing belt can't be that hard... There's lots of good links on here :)
Reply #13March 22, 2011, 05:49:08 pm
macka
  • 957
« Reply #13 on: March 22, 2011, 05:49:08 pm »
and Giles can be found here
