Author Topic: na to td conversion turbo coolant line questions  (Read 25866 times)
Reply #30March 21, 2011, 11:26:26 am
Re: na to td conversion turbo coolant line questions
« Reply #30 on: March 21, 2011, 11:26:26 am »
the garretts usually were fed by the 2.5 tho werent they?
and even being that they spool @ 2500, thats still going to add about 1k rpms to the spool on a 1.6L engine...
take that same T3, bolt it on a 350 chevy, and it will probably be damn near boosting at idle..
its all about the air you feed the turbo.. if you dont have enough to feed it, its not gonna operate the way you want it to..
(14psi on a T3 is nothing BTW.. its just starting to stretch its legs a bit)
Reply #31March 21, 2011, 11:46:55 am
bgbmxer
  • 107
« Reply #31 on: March 21, 2011, 11:46:55 am »
No garretts were only on the 2.2s and the mitsu on the 2.5 which the mitsu is smaller. And yea that garrets good till about 20 lbs till it gets inefficient. But this was a non intercooled car so 14s plenty of boost for that.
The mitsu I think spooled 7 to 800 rpm sooner on the same engine I think so it might not be to bad if I port everything out
Reply #32March 21, 2011, 08:05:57 pm
« Reply #32 on: March 21, 2011, 08:05:57 pm »
porting is not going to make up for 900cc's, and 1000 rpms more capability..
but go for it, atleast you will have a real good base ready for a real diesel turbo if you decide to go that way/find one cheap enough..
Reply #33March 22, 2011, 01:37:36 am
bgbmxer
  • 107
« Reply #33 on: March 22, 2011, 01:37:36 am »
Porting is how a Honda that's a 1.6 can run a turbo thats 3 times bigger than the one I plan on using and still make usable boost. Yes they rev higher and have more valves but do you think any 1.6 without tons of head work could ever spin a huge t3 t4 or bigger I think not.
I wish there was room for bigger valves and I would put bigger valves in too
Reply #34March 22, 2011, 05:07:25 am
« Reply #34 on: March 22, 2011, 05:07:25 am »
Gas is a little different than diesel, but I see you have it all figured out. I will love to see a dyno report when you are done. Please keep us posted. It should be great.
Reply #35March 22, 2011, 06:06:48 am
bgbmxer
  • 107
« Reply #35 on: March 22, 2011, 06:06:48 am »
Is this sarcasm? Or actual interest? And no I do not have everything figured out but there is one guy using the same turbo making big power so why can't I. Im not saying it's gonna work great but I don't see it being that horrible either.
Reply #36March 22, 2011, 08:46:37 am
« Reply #36 on: March 22, 2011, 08:46:37 am »
i think it will work well, dave did 196whp with a t3 to4e which is much larger than the dodge turbo, who cares if its gas or diesel, our diesels rev nearly as high as a gassers especially with the governor mod.  the only difference on daves engine was a lightly ported aaz head and a giles pump.
Reply #37March 22, 2011, 09:22:11 am
« Reply #37 on: March 22, 2011, 09:22:11 am »
5600 RPMs is a LONG WAYS off from 9000 like most gasser engines torn to make power with oversized turbos..
hondas can spool a HX30, because they spin ~9000 rpms to do it, and the turbo doesnt come to life til 4500 rpms..
Reply #38March 22, 2011, 09:29:57 am
bgbmxer
  • 107
« Reply #38 on: March 22, 2011, 09:29:57 am »
We will see. I ordered pipe to fab the downpipe so no turning back now
Reply #39March 22, 2011, 09:34:40 am
bgbmxer
  • 107
« Reply #39 on: March 22, 2011, 09:34:40 am »
Yea and that turbo is on a how many liter engine factory and is how many times bigger and flows more than the turbo I'm using?
Reply #40March 22, 2011, 10:09:50 am
« Reply #40 on: March 22, 2011, 10:09:50 am »
lol, i was using it as an example, thats all.. nothing more.
Reply #41March 22, 2011, 01:45:47 pm
bgbmxer
  • 107
« Reply #41 on: March 22, 2011, 01:45:47 pm »
Dont the rods fail around that horsepower?
Reply #42March 22, 2011, 02:09:06 pm
« Reply #42 on: March 22, 2011, 02:09:06 pm »
Rods fail from torque.  If memory serves he was revving pretty high for that.
around 4800 IIRC?
you bend rods at low RPMS..
not high rpms..
Reply #43March 22, 2011, 03:26:18 pm
Reply #44March 22, 2011, 04:04:52 pm
bgbmxer
  • 107
« Reply #44 on: March 22, 2011, 04:04:52 pm »
ok  heres the specs of my turbos hopefully someone can post the specs of the turbos on the vws
TEO4H specs:
   Compressor housing A/R   small
 Exhaust housing A/R  smaller
 Compressor inducer   38 mm
 Compressor exducer  53 mm
 Exhaust turbine diameter  51 mm
TO3 TII specs:
   Compressor housing A/R   .42
 Exhaust housing A/R  .48
 Compressor inducer   42 mm
 Compressor exducer  60 mm
 Exhaust turbine diameter  48 mm
VNT25 specs:
   Compressor housing A/R   .48
 Exhaust housing A/R  .64
 Compressor inducer   36 or 40 mm
 Compressor exducer  52 mm
 Exhaust turbine diameter  small
TBO3 specs:
   Compressor housing A/R   .52
 Compressor inducer   45 mm
 S60 specs:
 Exhaust housing A/R  .63
 Compressor inducer   48.5 mm
compare away
« Last Edit: March 22, 2011, 04:10:07 pm by bgbmxer »
