Author Topic: pressure washing  (Read 5068 times)
March 10, 2011, 05:32:48 pm
pressure washing
« on: March 10, 2011, 05:32:48 pm »
Is mean green / spray nine safe for the auxiliary suck up tube of the pressure washer??
Got a mean dirty bay to wash.. And need some ooomph lol
Reply #1March 11, 2011, 12:21:02 am
maxfax
  • 2126
Re: pressure washing
« Reply #1 on: March 11, 2011, 12:21:02 am »
I've run that and worse though mine..  Just make sure to flush it out good when your done..
Reply #2March 11, 2011, 09:00:39 am
« Reply #2 on: March 11, 2011, 09:00:39 am »
purple power is corrosive..
i assume you are talking about simple green? or is there some sort of cleaner called mean green?
is what i do, is let the engine ALMOST warm up, then shut it of and spray it down with cheaner, then let the cleaner almost dry on the engine, then i just hose it off, engine comes out looking like you just pressure washed it..
DO NOT WASH THE ENGINE COMPARTMENT OF A GASSER W/ A DIZZY!!
it will be a couple days till it runs good again..
Reply #3March 11, 2011, 09:06:20 am
maxfax
  • 2126
« Reply #3 on: March 11, 2011, 09:06:20 am »
There is stuff called mean green which is more or less a simple green knock off...   Spray-Nine is probably closer to purple power but is also a disinfectant..
Purple power can be some nasty stuff..   I use it in an old dishwasher to clean engine parts..  Set to pots and pans and it's been known to remove the paint from tin parts...
Reply #4March 11, 2011, 10:04:13 am
« Reply #4 on: March 11, 2011, 10:04:13 am »
purple power will turn aluminum soo white its not even funny..
simple green has never hurt any metal ive cleaned with it..
ZEP-a-lume works very good.. its a cleaning acid specifically for aluminum and that sort of thing..
Reply #5March 11, 2011, 10:31:15 am
« Reply #5 on: March 11, 2011, 10:31:15 am »
Will mostly be doing the engine bay, the engine itself is pretty spotless. I don't want it to peel paint, just the stubborn 30 year old grunge.
Reply #6March 11, 2011, 10:56:06 am
maxfax
  • 2126
« Reply #6 on: March 11, 2011, 10:56:06 am »
You should see a water pump housing after extended use as a coolant..  Simple green is amazing stuff..  You can actually safely drink the stuff yet it cleans damn good..
Jeremy, you should be fine with any sort of degreaser.. The ticket is to not let it soak on there too long.. (like for days) And once again if you're running it though the pressure washer makes sure you flush that out really well when you are done..
Hot water would be a huge help!!  But if you do have a hookup to use it, make sure your pressure washer is deigned to handle hot water..  Ask me how I know that some pressure washers are not rated for use with hot water..  ::)
Reply #7March 13, 2011, 08:46:39 am
macka
  • 957
« Reply #7 on: March 13, 2011, 08:46:39 am »
I used the spray on foamy orange cleaner from crappy tire as a pretreatment. I also used a crap load of other stuff through the washer, just ran a big pail of water through the pick up at the end.
Quote from: Vincent Walden
Reply #8March 13, 2011, 01:19:06 pm
GEE-BEE
  • 1604
« Reply #8 on: March 13, 2011, 01:19:06 pm »
I have a Karcher pressure washer, I use simple green and a scrub brush
I really dont have anything on the truck that isnt powder coated, so sometimes it's just road grime
I do use the washer on the bedrug liner .
I also use the washer with my spotless deionizer for a perfect finish..
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
