Author Topic: Need some engine info  (Read 6632 times)
Reply #15February 26, 2011, 07:50:51 pm
coke
  • 254
Re: Need some engine info
« Reply #15 on: February 26, 2011, 07:50:51 pm »
Yeah, well how about the power steering pump that looks like it took a bath in the atlantic ocean? I couldn't get the 13mm bolt that goes through the spacer bracket to the other side of the pump to turn at all. Nut rounded off. I had to dig out a dremel and grind it off completely. I swear the vehicle must've been a Katrina car.
It was awful, and to make matters worse someone had stripped one of the thermostat flange bolts so I had to find a way to hold a nut on top and turn a wrench too. Needless to say, its the last thermostat it will see. ;) (Gasser, not a diesel)
Reply #16February 26, 2011, 07:54:39 pm
maxfax
  • 2126
« Reply #16 on: February 26, 2011, 07:54:39 pm »
That's the one I was thinking so fondly of..   A nickel's worth of never seize would have gone a long way on that...
Reply #17February 26, 2011, 08:11:39 pm
macka
  • 957
« Reply #17 on: February 26, 2011, 08:11:39 pm »
Never sieze, always get used on the accessories bolts and nuts during reassambly. Saves agravation and I don't involuntarily donate blood.
Quote from: Vincent Walden
Reply #18February 26, 2011, 08:15:11 pm
« Reply #18 on: February 26, 2011, 08:15:11 pm »
I use never sieze like most people use silicone gasket maker. I would rather have it up to my elbows than to bust one of the water pump bolts ever again. The GTI I did last summer I broke the Tstat bolts off in the housing. I stole the good housing off of another engine that I had already never siezed up a few years ago. Worked perfect.
Reply #19February 26, 2011, 08:23:40 pm
maxfax
  • 2126
« Reply #19 on: February 26, 2011, 08:23:40 pm »
Don;t get me started on that..  ::)
It's a darned shame cars are built with roughly a 5 - 10 year lifespan in mind..  I'd be willing to pay a few extra bucks to know they never seized some stuff..
Reply #20February 26, 2011, 08:37:30 pm
« Reply #20 on: February 26, 2011, 08:37:30 pm »
You know what I mean? When there is 12lbs of silicone on what used to be a valve cover and it is leaking all over the place. Squished in so far that it was probably hitting the cam...yeah that is me only with the nickel anti sieze ;) It will be on the bolt, the head of the bolt, on the shank of the bolt, all up in them threads of the bolt and then I will usually thread the brush onto the nut before assembly.  ;D
Reply #21February 27, 2011, 06:25:56 am
dodger21
  • 97
« Reply #21 on: February 27, 2011, 06:25:56 am »
Sorry folks, I was just venting a bit.
Didn't know about the power steering pump being there....
Maxfax, it is easy if you turn the wheels all the way to the right. I can change oil in that thing faster than it takes to put the gas in it.  :o
1985 Golf 1.6NA with a 5spd
Reply #22February 27, 2011, 09:10:33 am
« Reply #22 on: February 27, 2011, 09:10:33 am »
try replacing a t-stat on a car with a/c and power steering!
im used to a thermo change taking about 15 minutes. ive only owned 2 Volkswagens in my life with power steering, and only 3 with a/c..
Reply #23February 27, 2011, 09:56:00 pm
maxfax
  • 2126
« Reply #23 on: February 27, 2011, 09:56:00 pm »
Yes!  Once I figured that out it wasn't so bad..  I was being slow that day I suppose...
