Author Topic: Need some engine info  (Read 6824 times)
February 25, 2011, 05:56:59 pm
dodger21
  • 97
« on: February 25, 2011, 05:56:59 pm »
Looking to replace T-Stat and do an oil change but I need to know how much of each. Thanks!
1985 Golf 1.6NA with a 5spd
Reply #1February 25, 2011, 06:10:11 pm
GEE-BEE
  • 1604
Re: Need some engine info
« Reply #1 on: February 25, 2011, 06:10:11 pm »
Gallon of coolant and a gallon of distilled water, I use G12 type
I get the shell rotella synthetic 5qt at Wallmart
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 25, 2011, 06:38:13 pm
mystery3
  • 774
« Reply #2 on: February 25, 2011, 06:38:13 pm »
GB
I used to go to walmart/hell to get the 5qt jugs but they now only sell 1g/3.78L jugs and it didn't appear they lowered the price. Now it's just not worth venturing in to the depths of hell on earth/walmart just to buy oil. I've found bmw, saab and vag coolants are all the same and it's the cheapest at the saab dealer if they've one anywhere near you it might be worth it.
Reply #3February 25, 2011, 06:42:13 pm
« Reply #3 on: February 25, 2011, 06:42:13 pm »
buddy of mine works at advanced...I bring up the oil he says "looks like napa is having a sale and we need to price match" I just smile.
As much as I drive I should have built 2 of these engines and bought a drum of oil
Reply #4February 25, 2011, 06:57:52 pm
« Reply #4 on: February 25, 2011, 06:57:52 pm »
Dunno if it was available in 1985...but does your car have power steering?
Reply #5February 25, 2011, 07:51:11 pm
dodger21
  • 97
« Reply #5 on: February 25, 2011, 07:51:11 pm »
No power steering.  :D
Thanks guys!
Reply #6February 25, 2011, 09:44:10 pm
Baron VonZeppelin
« Reply #6 on: February 25, 2011, 09:44:10 pm »
Yes available in 85. My 85 Jetta TDGL is pwr str and its on the window sticker.
A gallon of coolant and gallon of distilled has never been enough in my mk1-mk2 VW's ... but they all have factory A/C. Which usually means a larger radiator capacity. fwiw
Reply #7February 25, 2011, 10:01:13 pm
« Reply #7 on: February 25, 2011, 10:01:13 pm »
Cool... then t-stat changeover is *much* easier:
- with a catch pan in place remove the two 10mm bolts holding the t-stat housing to the water pump
- pull the housing free
- stand clear of a whoosh of coolant  ;)
- pull out the t-stat
- stand clear of the second whoosh of coolant ;-)
Reply #8February 26, 2011, 01:23:03 am
Thezorn
  • 381
« Reply #8 on: February 26, 2011, 01:23:03 am »
Thanks guys!
If only everyone was this lucky :P
Compounded 93 AAZ
Reply #9February 26, 2011, 03:36:30 pm
dodger21
  • 97
« Reply #9 on: February 26, 2011, 03:36:30 pm »
WTH?!?!?!?!
That was one of the WORST thermostat placings ever! Took me 45mins to get it in! But not it doesn't leak around there anymore and the temps don't spike.
Reply #10February 26, 2011, 04:42:18 pm
mystery3
  • 774
« Reply #10 on: February 26, 2011, 04:42:18 pm »
WTH?!?!?!?!
How many vehicles have you had? It's a little bit of an awkward angle but not bad at all compared to a lot of cars out there.
Reply #11February 26, 2011, 05:12:37 pm
nathan_b
  • 361
« Reply #11 on: February 26, 2011, 05:12:37 pm »
try a 1.8t jetta or golf thermostat.. without removing the manifold or the front end that it...
Reply #12February 26, 2011, 05:18:44 pm
dodger21
  • 97
« Reply #12 on: February 26, 2011, 05:18:44 pm »
1990 F150, 1987 GMC Suburban, 1993 4x4 Cummins, 1997 Saturn SC1, 1995 Ford E350,1993 Ford Crown Vic, 1993 2wd Cummins, 1985 Golf. Except for the Ford E350 and the 4x4, I changed all of the thermostats at one time or another. I only have the Crown Vic and the Golf now. The Vic I have owned the longest at 2 years last month. Body is darn near perfect, with 210k miles on it, 3 owner car that my in-laws bought off of a grandma who drove it 30k miles in 8 years. I got that thing for $10 as they wanted to GIVE it away. They claimed no one would want a 16 year old 180k mile car for $500...  ;D
Reply #13February 26, 2011, 05:47:09 pm
« Reply #13 on: February 26, 2011, 05:47:09 pm »
WTH?!?!?!?!
Sorry dude... we have no sympathy... since you didn't have to move the power steering pump out of the way first.   ;) ;D ;D ;D
Reply #14February 26, 2011, 07:45:32 pm
maxfax
  • 2126
« Reply #14 on: February 26, 2011, 07:45:32 pm »
1993 Ford Crown Vic
 :'( :'( :'(  I miss my '98 & '93..    But the slightly annoying oil filter makes up for the T-stat..
No sympathy here either..  You haven't lived to you try removing a power steering pump that hasn;t been touched in 20+ years...
