Author Topic: clutch cable lubricant  (Read 4741 times)
February 24, 2011, 02:57:41 am
ilikevwdiesel
  • 1202
« on: February 24, 2011, 02:57:41 am »
anyone have any suggestions what to use as a lubricant for a mk1 clutch cable? maybe the pivot for the the pedal too.
My Bio
Reply #1February 24, 2011, 03:28:03 am
Fredrikkk
  • 155
Re: clutch cable lubricant
« Reply #1 on: February 24, 2011, 03:28:03 am »
WD40 worked great for my '87 Passat clutch cable..
1991 VW Golf Pasadena GTD - Yeah, it's awesome.
Reply #2February 24, 2011, 04:00:09 am
ilikevwdiesel
  • 1202
« Reply #2 on: February 24, 2011, 04:00:09 am »
I guess I was wondering if anyone had used something dry like graphite. once I sprayed some pb blaster down into a cable and it dribbled down onto the pedal and stunk up the cabin. shoulda pulled it off the vehicle... :D
My Bio
Reply #3February 24, 2011, 05:23:51 am
« Reply #3 on: February 24, 2011, 05:23:51 am »
The blaster TDL or Aervoe makes a dry moly lube. The graphite works well. I used a liquid moly lube, no more squeaking.
Reply #4February 24, 2011, 05:36:50 am
ilikevwdiesel
  • 1202
« Reply #4 on: February 24, 2011, 05:36:50 am »
do you have a specific brand or product?
My Bio
Reply #5February 24, 2011, 05:43:17 am
« Reply #5 on: February 24, 2011, 05:43:17 am »
Blaster TDL = Blaster brand teflon dry lube
Aervoe dry moly lube is just Aervoe 8078
Aervoe 6078 is a teflon lube
and the dry graphite I used was from 1990 or something when we put it on my brothers pine box derby car and I have no clue on what brand.
Reply #6February 24, 2011, 06:19:45 am
ilikevwdiesel
  • 1202
« Reply #6 on: February 24, 2011, 06:19:45 am »
ok cool thanks. this cable is on my AAZ caddy, i got it from NAPA. It doesn't look like the OEM ones do. I wonder if I should just replace it.
My Bio
Reply #7February 24, 2011, 07:21:58 am
« Reply #7 on: February 24, 2011, 07:21:58 am »
i use silicone spray on my cables..
Reply #8February 24, 2011, 07:57:29 am
« Reply #8 on: February 24, 2011, 07:57:29 am »
After painting a bunch of stuff I try to stay completely away from silicone spray. It works, but sucks if any residue is around when painting. I do use it though on my rubber components like the tie rod boots, cv boots, and what not. I usually can do that away from the car.
Reply #9February 24, 2011, 07:59:26 am
« Reply #9 on: February 24, 2011, 07:59:26 am »
i lubricate all my cables while OFF the car..
usualy clamp a piece of rubber hose over one end, and fill it up till it drips out the other end.. the rubber hose acts as a reservoir..
Reply #10February 24, 2011, 09:25:16 am
GEE-BEE
  • 1604
« Reply #10 on: February 24, 2011, 09:25:16 am »
bel ray syn grease for car
wd40 for girlfreind, no squeak's
still cant get RID of that moan ?
GB
« Last Edit: February 24, 2011, 09:58:14 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #11February 24, 2011, 10:08:23 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #11 on: February 24, 2011, 10:08:23 am »
I like the dry graphite. I used to run an old 600 Prentice log loader that had a bunch of these type of cables and I was always having trouble with them. This is just a theory but I think when I was using petroleum based lubricants they attracted dirt, and the dirt would get wet in the winter, and in turn cause rust in the cables. Of course logging is a much dirtier enviroment than most cars will ever see, but when I switched to the dry graphite it did cut down on my cable problems.
« Last Edit: February 24, 2011, 10:12:59 am by Rabbit79 »
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #12February 24, 2011, 05:36:09 pm
macka
  • 957
« Reply #12 on: February 24, 2011, 05:36:09 pm »
Sea Foam deep creep
Great Dane Trailers dry graphite spray (I use this on my semi auto rifle in the winter too)
Quote from: Vincent Walden
Reply #13February 24, 2011, 10:27:00 pm
« Reply #13 on: February 24, 2011, 10:27:00 pm »
White lithium grease in spray form is what I use for most anything inside of a vehicle.
It doesn't stain upholstery or clothes nearly as bad as other lubricants.
Reply #14February 24, 2011, 10:34:59 pm
mystery3
  • 774
« Reply #14 on: February 24, 2011, 10:34:59 pm »
Awesome! I completely forgot about pinewood derby cars since shortly before 1990 when I discovered girls.
I like graphite for locks, cables and pinewood derby car wheels!
