Author Topic: Transmission Selection Help 4or5sp?  (Read 12148 times)
Reply #45March 04, 2011, 07:41:56 am
GEE-BEE
  • 1604
Re:turbo's
« Reply #45 on: March 04, 2011, 07:41:56 am »
off subject, but there is new KO3's on ebay for less than a overhaul..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #46March 04, 2011, 08:58:00 am
trav1856
  • 230
Re: Transmission Selection Help 4or5sp?
« Reply #46 on: March 04, 2011, 08:58:00 am »
Nevermind, I should have stopped at just search.
Okay, I'm going to just ignore that as pretentious old-timer babble. Had you read what I had previously wrote, you would've seen "what I'm reading about...."
Logic would dictate that I have already searched, now wouldn't it?
1981 Rabbit Diesel
1981 Cabriolet
Reply #47March 04, 2011, 10:45:12 am
« Reply #47 on: March 04, 2011, 10:45:12 am »
now that is better, specific examples.
Okay, so we've complained about it. Have any of you gone to him and said, "hey, your intake manifold is incorrect"? or did you just come on here and complain? If you did go to him, did he make good on it?
I'm not knocking anyone, just playing devil's advocate. Being the critical thinker that I am. That's why we're here after all. There's no need for the "You're new here, aren't you". (this much is obvious, and doesn't need to be mentioned).
Okay, so hoses, belts (i've heard those are bad), I noticed his oilpan is out of stock, so yeah, it doesn't look good. Call this a litmus if you will, and I'm stirring the pot a lil'. I'm neither for or against anyone, however, I do like to see unbiased opinions backed up by as much factual information as possible.
if you dont believe us, then just buy something from him. i think you should buy an injection pump and see just how good the quality is?  ;D
