Author Topic: Advance IP sprocket on 1.6 NA  (Read 3291 times)
January 30, 2011, 06:46:31 pm
motomike33y
  • 190
« on: January 30, 2011, 06:46:31 pm »
getting my rab-jetta(rabbit engine in jetta) to live and run.  Had it running w/too much smoke so advanced IP as much as I could, but it still wanted to die when cold start pushed in, and only when warm would idle.  Wanted to try some more advance. Decided to try advancing the IP sprocket one tooth, did so, but no success now at even getting smoke to come out.  I rotated the sprocket one tooth toward the cam sprocket.   Now I wonder if that was the correct direction.  I returned the IP to a standard position-mark on IP lined up w/notch on mounting frame-no luck, then retarded it some, then slowly advanced till it was almost at the point it had been at before, still no firing or smoke.  Need to charge battery now, but welcome any suggestions.  Should the sprocket have been rotated away from the cam sprocket?  How much timing variation ie teeth can be accounted for within the normal advancing distance available by rotating the IP?  Thanks.
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1January 30, 2011, 08:22:06 pm
Wayland
  • 364
Re: Advance IP sprocket on 1.6 NA
« Reply #1 on: January 30, 2011, 08:22:06 pm »
turning it towards the cam sprocket retards the timing.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2January 30, 2011, 10:00:53 pm
motomike33y
  • 190
« Reply #2 on: January 30, 2011, 10:00:53 pm »
thanks-that would confirm my problem
2012 golf tdi
Reply #3February 02, 2011, 08:22:07 pm
motomike33y
  • 190
« Reply #3 on: February 02, 2011, 08:22:07 pm »
bingo-I moved sprocket two teeth away from cam, turned key, and it started right up.  still need to fiddle a bit, but thanks.
2012 golf tdi
S-PAutomotive.com
