Author Topic: My new ride, a '92 2 door golf (pics)  (Read 12123 times)
Reply #30May 12, 2011, 11:56:41 pm
Re: My new ride, a '92 2 door golf (pics)
« Reply #30 on: May 12, 2011, 11:56:41 pm »
Got it a lot better, still seems noisier than I thought it should be.........actually I just thought of I'm comparing it to how my friends MK2 TD sounds, of course that'll be quieter.
Shouldn't this be a lot quieter than say, a rabbit NA? haha I hope so.
I looked into the temp gauge thing and it's just the sender, jumping it to ground pegs it on high. Funny thing though is that both senders appear to be bad since switching the GP and gauge plugs doesn't help.
Reply #31May 13, 2011, 07:42:34 pm
« Reply #31 on: May 13, 2011, 07:42:34 pm »
Something is still not right with it. It starts hard and then misses but at the same time it clacks real bad, I'm thinkin' the fuel lines and stuff weren't clean enough and is causing leaky/clogged injectors or something.
I added a pint of seafoam to 5/8 tank of fuel so we'll see if it helps.
Is it OK to run straight seafoam?
Reply #32May 13, 2011, 07:49:27 pm
truckinwagen
  • 1895
« Reply #32 on: May 13, 2011, 07:49:27 pm »
I would stick some lubricity additive along with it just in case.
BTW diesel purge is goooooood stuff, and NAPA should have it/be able to get it.
-Owen
83 Opel Kadett Diesel
Reply #33May 13, 2011, 08:47:17 pm
« Reply #33 on: May 13, 2011, 08:47:17 pm »
-Owen
I might look into it.
Reply #34May 16, 2011, 01:57:14 pm
« Reply #34 on: May 16, 2011, 01:57:14 pm »
I hooked up an oil pressure gauge to the head since I was missing the stock sender anyways and wanted to know what it is.
Here it is.
Cold idle: 70-80 psi and doesn't change much when revved.
Hot idle: 10psi
Hot revved: 30-35psi
Driving longer would probably get the oil hotter but the rad fan had come on at least once.
I do not have a tach but I'd guess idle to be 1000-1100rpm (yes it idles high) and revved to be in the 3000-3500rpm range.
I think the low oil pressure is affecting the vacuum pump since it vacs real good when cold but once it's hot I have to rev it to get good brakes.
That's way to low for my liking and being a '92 it probably already has the 36mm oil pump.
Reply #35June 09, 2011, 10:00:16 pm
« Reply #35 on: June 09, 2011, 10:00:16 pm »
Just put my tach in
Much better than the big clock.
Do these tachs need calibrating? I assume it would be accurate as long as the crank and alternator pulleys are the same size as the car it came off of, but if they're not is there adjusting screws on it somewhere?
Reply #36June 10, 2011, 08:42:31 am
  • 5103
« Reply #36 on: June 10, 2011, 08:42:31 am »
i would say it is probably accurate, but i recommend that you double check. so long as your speedometer is accurate you can use your gear ratios to figure out what rpm you should be at at certain speeds
Reply #37June 13, 2011, 04:25:19 pm
« Reply #37 on: June 13, 2011, 04:25:19 pm »
I parked my rabbit close to the golf and used the rabbits tiny tach (accurate to within 1 rpm below 1000 and within 10 above 1000rpm) to test the accuracy of the analog tach. It seemed to vary from about 50-150 rpms off, fine for driving but not really for tuning the IP. It's accurate enough to get tuned better than it is now though ::).
Reply #38June 13, 2011, 06:48:58 pm
  • 5103
« Reply #38 on: June 13, 2011, 06:48:58 pm »
they're pretty simple to adjust if need be
Reply #39December 02, 2011, 08:24:46 pm
« Reply #39 on: December 02, 2011, 08:24:46 pm »
My stereo, notice my messed up dash, that's part of the reason I didn't put it where it's supposed to go.
The city lights on
This is were the temp gauge likes to sit, It's not overheating so do I need a different sender to lower the needle?
Looks good to me.........
The muffler was broke loose from the core so it could spin so I got a new Walker muffler from amazon, it's really quiet now.
I just gotta get it to start in the cold and I'll start driving it. ;D
Reply #40December 03, 2011, 04:16:35 am
Fredrikkk
  • 155
« Reply #40 on: December 03, 2011, 04:16:35 am »
Nice car!
My temp needle stays just under half at almost all times. I have a fan cooling switch too set to 84 degrees celcius I think too. Helps keep it cool :)
1991 VW Golf Pasadena GTD - Yeah, it's awesome.
Reply #41December 03, 2011, 01:31:24 pm
« Reply #41 on: December 03, 2011, 01:31:24 pm »
Nice car!
Thanks man.
The thing with the gauge is it's not overheating at all and the lower rad hose barely gets warm meaning the t-stat isn't opening much. I'll just live with it I guess, it sure is nice when the needle sits right in the middle though ;D.
Reply #42December 04, 2011, 07:21:52 am
srgtlord
  • 797
« Reply #42 on: December 04, 2011, 07:21:52 am »
I bet your Radiator or T-stat is fudged up......
Reply #43December 04, 2011, 11:18:27 am
« Reply #43 on: December 04, 2011, 11:18:27 am »
i dont think owen ever had any issues with the cooling system??
Reply #44December 05, 2011, 07:09:52 pm
« Reply #44 on: December 05, 2011, 07:09:52 pm »
He never even ran this car, he lost interest and sold it after buying the isuzu.
Like I said though, the needle sits too high but the actual temperature is not high. The top rad hose is not too hot to hold on to.
Just wondering if the sender is screwed (it's new) up or if it's the gauge. The sender is blue does that sound right?
