Author Topic: Where to get this gasket  (Read 4107 times)
January 08, 2011, 12:47:56 pm
« on: January 08, 2011, 12:47:56 pm »
Does anyone know where to get a single gasket for the block off plate on the front of the 1.6? It comes in the 20.00 bottom end gasket set, but I can't find it by itself. It is the one that goes on the cover for the intermediate shaft. I would rather not make one.
Reply #1January 08, 2011, 02:43:18 pm
81 vw pu
Re: Where to get this gasket
« Reply #1 on: January 08, 2011, 02:43:18 pm »
If I'm not mistaken a small block chevy fuel pump gasket will work.
Reply #2January 09, 2011, 10:05:48 am
« Reply #2 on: January 09, 2011, 10:05:48 am »
just lay a piece of thin cardboard or gasket paper over the block off plate and tap around the edge with a hammer, voila! instant gasket..
thats how i make gaskets atleast.. i love the looks i get from people when i tell them i use a hammer to build gaskets.
Reply #3January 09, 2011, 11:43:48 pm
maxfax
  • 2126
« Reply #3 on: January 09, 2011, 11:43:48 pm »
Fuel pump gasket from an early gasser with a carb..  Early Dodge Omni should work for an application
Here's the Carquest P/N's (I believe they are Victor numbers as well)  certainly someone can cross them..
Carquest P/N  D24076  or  D24097
Reply #4January 12, 2011, 02:16:59 am
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: January 12, 2011, 02:16:59 am »
bestpricecarparts sells em i believe as a "coolant flange gasket"
they are the same shape & size if you're talking about what i think you're talking about...
