Author Topic: Bend your brake pedal lately?  (Read 6796 times)
December 29, 2010, 10:15:14 pm
maxfax
  • 2126
« on: December 29, 2010, 10:15:14 pm »
I know I tend to be a bit hard on machinery, but... has anyone else bent their brake pedal or am I just a neanderthal?  I've bent 3 now over the past many years..  2 of them on previous Rabbits where during a panic stop with a failed vac pump, I thought nothing of it...  Straightened the one but it bent again..  Tonight I wailed on the brakes for a deer, brakes worked fantastically since everything was replaced, but once again the woah pedal is now too close the go pedal and I keep catching it with my big foot..
I know there probably really isn't any fix other than adding some reinforcement to the next pedal I install, but I was curious if anyone else has done this, or if I'm just too mean to the Bunny...
Reply #1December 29, 2010, 10:56:27 pm
« Last Edit: December 29, 2010, 11:06:54 pm by 745 turbogreasel »
Reply #2December 29, 2010, 10:56:52 pm
Re: Bend your brake pedal lately?
« Reply #2 on: December 29, 2010, 10:56:52 pm »
yup ;D
I've heard of it being done but never seen it........or done it 8)
Maybe your brakes are having issues.
« Last Edit: December 29, 2010, 10:59:08 pm by rabbitman »
Reply #3December 29, 2010, 11:13:19 pm
maxfax
  • 2126
« Reply #3 on: December 29, 2010, 11:13:19 pm »
  I replaced everything on the brakes about 3 weeks ago, I'm thinking it is just a matter that I'm used to the brakes sucking.. When I wailed the pedal things happened for once!  :o It went from 75mph to 0 PDQ...
Reply #4December 29, 2010, 11:31:49 pm
RadoTD
  • 513
    Stage WTF
« Reply #4 on: December 29, 2010, 11:31:49 pm »
11.3" rotors + girling 54 calipers + Hawk HP Plus + stainless lines = amazing  ;D
You won't go bending any brake pedals there!
Maybe you should gusset yours? just weld some extra support on there..
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #5December 30, 2010, 07:00:27 am
GEE-BEE
  • 1604
« Reply #5 on: December 30, 2010, 07:00:27 am »
MKII 16 v master and Corrado brakes here
all new s/s hardlines
Going with a set of 16 v spindles soon so I can install 100mm outer cv's
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6December 30, 2010, 08:55:41 am
« Reply #6 on: December 30, 2010, 08:55:41 am »
no, its not you brett.. these pedals are just weak. i bend all my pedals too. well, usually. and like you, its almost never on purpose.
one time i bent the pedal trying to bleed the brakes. brake line still had a little piece of lead in it from the split shot i used to fix a brake leak.
Reply #7December 30, 2010, 07:32:44 pm
maxfax
  • 2126
« Reply #7 on: December 30, 2010, 07:32:44 pm »
Thankyou Kevin.. I feel better now..  :)   They are rather chincy, I reached in there today and bent it back one handed..  :o  I suppose in reality now that the brakes are in decent working order, there is no need to stomp em as hard as I can..  Old habits die hard though, I'm gonna molest the next pedal and make it stronger...
Reply #8December 31, 2010, 06:02:05 am
« Reply #8 on: December 31, 2010, 06:02:05 am »
I thought the bending brake pedal was a German safety device so you didn't blow the seals out on the master cylinder :D
2 of my MKI I seem to recall now bending brake pedals. The 81 and 84 Rabbits I don't have anymore.
Reply #9January 02, 2011, 12:20:28 pm
maxfax
  • 2126
« Reply #9 on: January 02, 2011, 12:20:28 pm »
 Reinforcing the pedal seems like a bad idea to me.  It might keep you from bending the pedal, but cause some other component to fail in that panic stop situation and that other component will cause a total failure of the brake system and cause you to hit whatever you are trying to avoid.
The more I thought about it, and the lazier I got, I just slapped another in there.. I started visualizing the booster breaking outta the fire wall..  ;D   The brakes on this car have always been crap, and I just continued to "patch em up" to keep it going..  Now that they will actually work as they should I've got to train myself not to slam them so hard..
Reply #10January 02, 2011, 02:09:07 pm
« Reply #10 on: January 02, 2011, 02:09:07 pm »
Fastest braking and best control of the vehicle is just before the wheels lock up.  Once skidding, braking be extended and control of the vehicle is greatly diminished.  If you are locking up the wheels and skidding, then it is an indication to press slightly less hard rather than more hard.
A.K.A. Threshold Braking ;) learn to love it on non-abs cars lol
Reply #11January 03, 2011, 12:10:52 pm
« Reply #11 on: January 03, 2011, 12:10:52 pm »
ABS freaks me out.. i hate it that the pedal pushes back at you..
ive actually been in a wreck BECAUSE of ABS..
truck off the bank because it pushed back too hard and basically let the truck roll right off the road. had i had normal brakes, it would have never left the road..
