Author Topic: CV axle removal.  (Read 4112 times)
November 26, 2010, 10:38:52 pm
Thezorn
  • 381
CV axle removal.
« on: November 26, 2010, 10:38:52 pm »
What kind and size of bit do I need to remove the bolts that hold the cv axles to the transmision?
im guessing the nut at the opposite end of the axle (at the hub) is a 30mm.
Compounded 93 AAZ
Reply #1November 27, 2010, 10:58:09 am
Re: CV axle removal.
« Reply #1 on: November 27, 2010, 10:58:09 am »
8mm triple square bit.. for the inner axle bolts.
Reply #2November 27, 2010, 11:07:26 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #2 on: November 27, 2010, 11:07:26 am »
Go to Sears get yourself the allen head metric set and your in business...
Reply #3November 27, 2010, 12:06:21 pm
« Reply #3 on: November 27, 2010, 12:06:21 pm »
but its not an allen bolt?!
and an allen bit will mess up the splines of the bolt from my experiences.. i would just get the RIGHT bit..
« Last Edit: November 28, 2010, 09:31:37 am by R.O.R-2.0 »
Reply #4November 27, 2010, 03:37:34 pm
« Reply #4 on: November 27, 2010, 03:37:34 pm »
8mm triple square is what the inner CVs take just like 2.0 said.
30mm is what the outer nut is.
I have been taking the triple square bolts out and putting in regular socket head cap screws. The triple square always seem to be made of something a bit harder than butter. They rarely come out without stripping somewhere. I hate the job so I figure I may as well put some bolts in there that actually will take some abuse. Try it and see for yourself, I am guessing you will love it.
Oh, as a bonus you can pick up an 8mm hex socket about anywhere. Or use a hex key. When you loose or break your only 8mm triple square your hosed. :D
Reply #5November 27, 2010, 04:21:13 pm
Thezorn
  • 381
« Reply #5 on: November 27, 2010, 04:21:13 pm »
okay thanks guys, now im faced with the problem of finding one on the weekend, woo hoo
Compounded 93 AAZ
Reply #6November 27, 2010, 04:24:12 pm
« Reply #6 on: November 27, 2010, 04:24:12 pm »
Canadian Tire carries a set of four triple-square bits, under the "Powerbuilt" label:
Part number #25-3224-2
« Last Edit: November 27, 2010, 04:25:45 pm by Vincent Waldon »
Reply #7November 27, 2010, 04:45:31 pm
Thezorn
  • 381
« Reply #7 on: November 27, 2010, 04:45:31 pm »
Okay thanks vincent I used to work at canadian tire in the automotive department and I didnt even know powerbuilt made them.
You know to much.
Compounded 93 AAZ
Reply #8November 27, 2010, 07:17:50 pm
Thezorn
  • 381
« Reply #8 on: November 27, 2010, 07:17:50 pm »
As I figured, Canadian tire doesnt have them, and would most likley be about 2 weeks to get them. Napa will be my old hope tomorrow.
Compounded 93 AAZ
Reply #9November 27, 2010, 07:44:13 pm
madmedix
  • 204
« Reply #9 on: November 27, 2010, 07:44:13 pm »
Or you could go to Princess Auto and pay one third what CTC is asking for them....
'90 TD Jetta
Reply #10November 27, 2010, 07:59:39 pm
« Reply #10 on: November 27, 2010, 07:59:39 pm »
Sadly I don't think the wonder that is Princess Auto has made it to Terrace yet... but ya never know.
Reply #11November 28, 2010, 11:27:12 am
Thezorn
  • 381
« Reply #11 on: November 28, 2010, 11:27:12 am »
unfortunatley not, not yet at least. Prince george is the closest. But I really dont think my winter beater (89 mazda b2200, with a fake cabon fiber hood scoop) will make the 6 hour trek.  :P I will be able to check Napa is about half an hour when they open. Wish me luck.
Maybe Ill be able to post some picture of the progress on my car too once I can get the cv axles out.
Compounded 93 AAZ
Reply #12November 30, 2010, 08:59:55 am
Turftech
  • 113
« Reply #12 on: November 30, 2010, 08:59:55 am »
I second the hex socket bolts.  I had to go to a machine shop I know that carries oddball size hardware, but they are out there.  I think they were 8mmx45.  Cant remember the pitch.  50's are too long, and 40's are too short!  Have had them out several times now and they're still like new.  Well worth it.
'90 Jetta GL TD  570'000 Kms and counting (Gave her to a friend)
'92 Passat G60 Syncro Wagon 180'000kms. TDI conversion project
'87 Jetta Coupe 325'000kms. MF IDI conversion project
Reply #13November 30, 2010, 12:44:41 pm
« Reply #13 on: November 30, 2010, 12:44:41 pm »
m8-1.25
