Author Topic: Quietening down a 1.6td  (Read 8973 times)
November 10, 2010, 02:46:44 pm
Robb
  • 44
« on: November 10, 2010, 02:46:44 pm »
I have a Golf Mk2 GTD 1.6td, I love the car to bits however the noise of the engine is a bit loud.
Im just wondering if anyone has any tips or tricks I can use to help reduce the clattery noise of the engine.
I realise its not possible to turn it into a modern sounding diesel, but just thought someone may have a way of reducing it in some way.
Thanks
Reply #1November 10, 2010, 03:05:25 pm
Mark(The Miser)UK
  • 1557
Re: Quietening down a 1.6td
« Reply #1 on: November 10, 2010, 03:05:25 pm »
1) Retard slightly.
2) Get some nozzles that presquirt.
3) Reduce injector atomisation, by lowering break pressures.
Mark-The-Miser-UK
Reply #2November 10, 2010, 03:13:28 pm
« Reply #2 on: November 10, 2010, 03:13:28 pm »
1. Increase stereo volume.
As mentioned, the timing affects the sound of the engine so at least make sure the timing is within specs. There are all sorts of products to reduce the amount of ambient noise coming into the passenger compartment, car audio places often have these, they are usually painted on or are adhesive-backed pads.
Reply #3November 10, 2010, 03:16:39 pm
GEE-BEE
  • 1604
« Reply #3 on: November 10, 2010, 03:16:39 pm »
Hood insulation or new valve's
maybe a louder girlfriend ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4November 10, 2010, 05:38:25 pm
FuryriderX
  • 14
« Reply #4 on: November 10, 2010, 05:38:25 pm »
'84 rabbit L diesel
'01 golf tdi
Reply #5November 10, 2010, 07:14:35 pm
dennis
  • 311
« Reply #5 on: November 10, 2010, 07:14:35 pm »
Take the kids along
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #6November 10, 2010, 08:45:10 pm
« Reply #6 on: November 10, 2010, 08:45:10 pm »
this works for me ;)
Reply #7November 10, 2010, 08:51:43 pm
« Reply #7 on: November 10, 2010, 08:51:43 pm »
good as new lifters properly shimmed :)
Reply #8November 10, 2010, 09:07:40 pm
RadoTD
  • 513
    Stage WTF
« Reply #8 on: November 10, 2010, 09:07:40 pm »
I noticed once that my engine was significantly quieter while driving on a very wet road... I think this was largely due to sound not being able to deflect off of the ground as well. Since then I've been thinking about making basically a skid plate to keep engine noise down. Apparently the TDI's have something like that... maybe worth looking into and trying out? I'll probably try it on my car eventually, but it'll be a while. Maybe you could make one and let me know how well it works? :D
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #9November 11, 2010, 02:01:43 am
regcheeseman
  • 714
« Reply #9 on: November 11, 2010, 02:01:43 am »
Fit a nice quiet petrol engine.
(runs away and hides)
Reply #10November 11, 2010, 07:05:25 am
Alcaid
  • 549
« Reply #10 on: November 11, 2010, 07:05:25 am »
Driving on snow is therapy for the ears. The original sound deadening under the motor is often lost/removed. Try that as a first step. Then Dynamat the whole car ;)
'10 VW Passat 1.6TDI Highline
Reply #11November 11, 2010, 07:30:11 am
spencebm
  • 686
« Reply #11 on: November 11, 2010, 07:30:11 am »
VR6 and ten mufflers
Ben Spencer
Reply #12November 11, 2010, 07:43:05 am
blackdogvan
  • 574
« Reply #12 on: November 11, 2010, 07:43:05 am »
Go look at a mk3/4 tdi & see how much insulation / sound deadening material is both on the hood and under the engine.
Can you run 2 stage aaz injectors in a 1.6? I always thought my aaz was reasonable once warmed up.
1991 Vanagon 1.9 mTDI
Reply #13November 11, 2010, 09:02:42 am
rallydiesel
  • 1880
« Reply #13 on: November 11, 2010, 09:02:42 am »
Yes but they are taller, so you would have to deal with the hardlines somehow. Maybe try AAZ hardlines but I think the pump sticks out further back so they may not line up either.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #14November 11, 2010, 04:43:52 pm
« Reply #14 on: November 11, 2010, 04:43:52 pm »
Yeah, they come with 7-10 things like that.
Burning veg seems to run a tad quieter, and  injector nozzle condition is also a factor.
