S-PAutomotive.com
Author Topic: Preparing a HYDROLIC! CY engine for boost  (Read 3897 times)
November 03, 2010, 12:41:16 pm
scaremercy
  • 5
« on: November 03, 2010, 12:41:16 pm »
Hello,
After using the search, i'm still stuck with some questions.
I have a hydrolic 1.6 turbodiesel motor, from a mk1 golf, enginecode CY.
Since i've blown the headgasket due to too much boost, i'm willing to instal a metal hg form a 1.9 AAZ engine and a head from a mk2 engine, code JR or SB.
What are the problems i can expect?
Is the JR or SB head plug & play on the hydrolic CY block? Do i have to modify the 1.9 headgasket?
Is is recommendable to use ARP headstuds? or are the original td ones good enough? can i use the ARP 1.8 gasoline headstuds? since i can't find any specified diesel ones.
My goal is arround 150-160 wHp.
Also, what is recommendable? putting the thickest Hg in the engine, or stick to the original thickness?
a lot of questions, I know :p but I want this done properly :)
Any input is appreciated :)
Greetings
« Last Edit: November 03, 2010, 12:54:12 pm by scaremercy »
Reply #1November 03, 2010, 01:19:26 pm
rabbitman
  • 2787
Re: Preparing a HYDROLIC! CY engine for boost
« Reply #1 on: November 03, 2010, 01:19:26 pm »
Are you sure it's a hydraulic head? I thought all MK1 were mech.
If it is really hydro then a metal HG will slap right in, a different head won't help anything.
If you're trying to gett that much power you should go with ARP. Look in the FAQ for the part number of the right ones.
I'd for sure use the correct head gasket, otherwise the quench area won't be like it's supposed to be.
Reply #2November 03, 2010, 01:48:04 pm
scaremercy
  • 5
« Reply #2 on: November 03, 2010, 01:48:04 pm »
It's a euro engine, and very rare.. pulled it out of a german mk1.
I would like to replace the head with a JR/SB head if possible because a corner of one of the threads used for fitting the exhaust manifold broke off. I could try to alluminium weld it, but i prefer a new head since i've got some spare ones from an JR/SB.
Allright, ARP studs and the correct Hg it is then :)
Reply #3November 03, 2010, 01:53:09 pm
arsenicpants
« Reply #3 on: November 03, 2010, 01:53:09 pm »
later mk1 diesels were hydraulic
83-84 i think
Reply #4November 03, 2010, 02:03:28 pm
Quantum TD
  • 1195
« Reply #4 on: November 03, 2010, 02:03:28 pm »
83-84 i think
Not in the USA
Reply #5November 03, 2010, 02:21:23 pm
MJF
  • 581
« Reply #5 on: November 03, 2010, 02:21:23 pm »
Hydraulic lifters came in 1985, so never from factory in mk1.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6November 03, 2010, 02:43:17 pm
« Reply #6 on: November 03, 2010, 02:43:17 pm »
My CY block I'm rebuilding right now is mechanical. I think there is a coolant passage difference between mech/hydro heads. I wouldn't think a single block code would have that kind of variation.... Are you 100% sure the code is CY?
Reply #7November 03, 2010, 02:52:15 pm
MJF
  • 581
« Reply #7 on: November 03, 2010, 02:52:15 pm »
CY is also used in Audi 80 and VW Passat. With hydraulic lifters too.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #8November 03, 2010, 03:01:04 pm
scaremercy
  • 5
« Reply #8 on: November 03, 2010, 03:01:04 pm »
Yes, 100% sure its a CY.. i pulled it out of a german mk1 golf. It has been a replacement engine in that mk1. So it could also come from a different car, like a passat or so.
Reply #9November 03, 2010, 03:11:57 pm
  • 3255
    • My collection of HOWTOs
« Reply #9 on: November 03, 2010, 03:11:57 pm »
Reply #10November 04, 2010, 02:29:19 pm
« Reply #10 on: November 04, 2010, 02:29:19 pm »
most ME blocks ive seen were hydro
most MF blocks ive seen were mech
the CY that came from my 84 rabbit, mech..
The USA didnt get hydro lifters till 86..
And why not use an AAZ head, instead of another 1.6 head? the AAZ head flows way better..
Reply #11November 06, 2010, 01:42:58 am
glenlloyd
  • 4
« Reply #11 on: November 06, 2010, 01:42:58 am »
And not all 86 Mk2 ME engines got hydraulic, it was introduced mid-year. I've had one of each, early car with mech lifters and later with hydraulic.
steve a
1986 Golf D, 1997 Jetta TDI
Reply #12November 08, 2010, 06:12:24 pm
scaremercy
  • 5
« Reply #12 on: November 08, 2010, 06:12:24 pm »
Because i haven't got an AAZ head lying around here, but have several 1.6 heads..and except that.. i would like to have no starting problems.. my girl is going to drive the car sometimes, and she can't even change the wheels ^.-
Reply #13November 08, 2010, 06:59:18 pm
Powered by Spearco
  • 1203
« Reply #13 on: November 08, 2010, 06:59:18 pm »
I've got a 1.9 AAZ head on a 1.6 MF mechanical block, and I have no starting problems with the block heater pluged in  ;D.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #14November 09, 2010, 06:34:20 am
Alcaid
  • 549
« Reply #14 on: November 09, 2010, 06:34:20 am »
Hydro head on a mech block? Did you block of the extra oil drain in the head?
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound ;)
Fixmyvw.com
