Author Topic: Preparing a HYDROLIC! CY engine for boost  (Read 4751 times)
Reply #15November 09, 2010, 08:07:54 am
Powered by Spearco
  • 1203
Re: Preparing a HYDROLIC! CY engine for boost
« Reply #15 on: November 09, 2010, 08:07:54 am »
Um, you have to  ::).
I blocked the drain in the head with an aluminum plug.
I blocked the coolant hole on the block with a chunck of rubber.
I'm pushing 30psi of boost, and it holding just fine.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #16November 09, 2010, 09:31:25 am
« Reply #16 on: November 09, 2010, 09:31:25 am »
I've been there as well.
Used a Hydro head on a solid block.
I welded up the coolant passage in the block and welded the hole in the head up.
Drilled the head and block for the extra AAZ coolant holes.
Reply #17November 09, 2010, 09:02:32 pm
Powered by Spearco
  • 1203
« Reply #17 on: November 09, 2010, 09:02:32 pm »
The AAZ head has the smaller steam holes already and its the block that you drill out.
Thats what I did.
'13 Golf R:. Tuned
'98 Puch G320
