Author Topic: 1300kms out of a tank of Fuel Challenge  (Read 8963 times)
October 31, 2010, 09:09:48 am
catlin_cava
  • 1954
« on: October 31, 2010, 09:09:48 am »
Well Sibling rivalry was gotten to me and my sister and we are having a contest...Who can get 1300kms out of a tank of fuel in a TDI.
We both own a Jetta TDI, Mines a 2001 ALH and hers is a 2002 ALH "Drivers Edition". Both cars have roughly the same mileage
Hers has 414K and mines got 424K. She JUST had a transmission put it and its got 98,000kms. so this is where I stand right now
4 New tires at 32PSI(Winters).
ALL NEW REAR BRAKES Nothing is dragging anymore ;D
My commute is 134.4kms a day round trip with 5kms of somewhat "city" driving 1 light lol.
Whats the BEST ways to get the most out of a tank since I JUST filled up the car right now and only have 8kms on the tank.
Clutch and coast getting off the highway? Clutch and Coast down LONG hills? MAX Idle warm up time in the morning (temps around Freezing)
and I did fill the car RIGHT to the top of the neck! ;D
and the most shes gotten so far was 1263kms......and she was waiting for roadside to pick it up to bring her to the gas station  ::)
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1October 31, 2010, 10:00:45 am
Patrick
  • 1034
Re: 1300kms out of a tank of Fuel Challenge
« Reply #1 on: October 31, 2010, 10:00:45 am »
Run the tire pressure up some more, and drive like there's raw eggs on the pedals (fuel AND brakes). Don't use the brakes at all if you can get away with it. Biggest thing:  KEEP THE SPEED and ACCELERATION DOWN!
Reply #2October 31, 2010, 10:44:51 am
cyrus #1
  • 360
« Reply #2 on: October 31, 2010, 10:44:51 am »
You will actually burn more fuel coasting in neutral than coasting down in gear.  In many cases the ECU will cut fuel completely when it senses you are coasting in gear.
I'm with Patrick.  Keep the speed between 90-100km/hr.  Faster = more drag = more fuel burned.  I got nearly 5mpg in my gasser when I boosted the tire pressure from 32 psi up to about 48 psi.  Keep in mind that you will lose some traction due to less surface area on the road.
Try to minimize the electrical load as well.  Don't use the heated seats or crank a 1,000 watt stereo.  I would also suggest running a fuel additive that boosts cetane.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #3October 31, 2010, 10:45:17 am
  • 1739
« Reply #3 on: October 31, 2010, 10:45:17 am »
Winter tires should be pumped up to 33 on those models anyways, so in your case, why not 35.
30 second warm up, drive slow for another 2 then gradually build revs.
 Do you have a scanner or even, better- vag-com. If so, plug in and there is more than one channel where you can see real time fuel consumption
Reply #4October 31, 2010, 11:47:17 am
catlin_cava
  • 1954
« Reply #4 on: October 31, 2010, 11:47:17 am »
My cars downfall is I have a 120AMP Alternator on her, I have no Scanner or VAG I want to get one its on my Wish list lol. Ill pump the tires up some PSI's Tomorrow, there are 2 reasons Id like to get high mileage a tank is I go to school so I have no income and my commute takes me to college  ;)
Catlin
Reply #5November 01, 2010, 09:28:43 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: November 01, 2010, 09:28:43 am »
Plug it in overnight to reduce warmup time.   That will help a bit.  Make sure your air filter is clean.   PowerService Cetane Boost (white container) was good for about 2 mpg on my car.   Air pressure in tires as mentioned can be big.   For example, my brother's Subaru as delivered had 24 psi in the tires.   When he checked and filled to the recommended 32 psi after 1 month, his mileage increased by almost 200 km per tank.    Extra pressure can reduce tire tread life (at least in the centre), but if you're just trying to max your mileage for one tank, I would take it to whatever is listed as the max on your tire sidewalls.    As mentioned, drive like you have a raw egg between your foot and the fuel pedal.   Look way down the road for what traffic is doing,  time traffic lights, don't go through any drive-throughs, don't leave the car idling.   Plan your travels to avoid as many hills as possible - pick the flattest roads even if it adds distance.
Calvin
91 VW Golf 1.6NA 5spd
Reply #6November 01, 2010, 10:45:24 am
« Reply #6 on: November 01, 2010, 10:45:24 am »
Yup, what Andrew said, I went on a trip in my rabbit with 4 passengers and gear over lots of hilly terrain. I went real easy on hills, letting it slow a little and then on the downhills use the hill to get back up to speed.
The trip was just under 500 miles and after I got back I didn't fill up for a day or two, that tank got about 530 miles, my best at the time.
Reply #7November 01, 2010, 11:31:56 am
410
  • 581
« Reply #7 on: November 01, 2010, 11:31:56 am »
I would also add some lucas upper cylinder lubricant to the fuel.  I notice a significant increase in mpg's when using it.  It's also kind of cheating since this stuff does burn and provides energy.  I've used double the suggested amount(.250L for our tanks) with no negative effects.
One of my Bosch manuals also suggests lower rpm and higher load for better efficiency instead of high revs and low load.  Good Luck.
The girlfriend and I have achieved 1300 km on a tank traveling across the country and the fuel light wasn't even on yet, so I know it is possible.
Reply #8November 14, 2010, 11:00:54 pm
79rabbit4dr
« Reply #8 on: November 14, 2010, 11:00:54 pm »
 :-\ isn't that a BAD thing? Maybe it's just on gas cars but that can screw up the evap system. Same with parking nose down on a really steep hill... or so I vaguely remember hearing.
Reply #9November 15, 2010, 08:59:57 am
« Reply #9 on: November 15, 2010, 08:59:57 am »
No EVAP system on a diesel my friend.
Fill that suka up!!!!
Reply #10November 18, 2010, 07:16:56 pm
79rabbit4dr
« Reply #10 on: November 18, 2010, 07:16:56 pm »
Cool, wasn't sure about the post-1996 OBD-II systems. Is it just a matter of diesel not being so vaporous?
« Last Edit: November 19, 2010, 04:05:40 pm by 79rabbit4dr »
Reply #11November 18, 2010, 08:23:37 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #11 on: November 18, 2010, 08:23:37 pm »
 its 1996 and up for OBD II
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #12November 19, 2010, 04:07:21 pm
79rabbit4dr
« Reply #12 on: November 19, 2010, 04:07:21 pm »
oops, thanks for catching that! '96, and even some as early as '94 were OBD-II compliant.
Reply #13November 19, 2010, 04:55:17 pm
dankcorey22
  • 379
    Cummins!
« Reply #13 on: November 19, 2010, 04:55:17 pm »
really? what makes were '94 and up? or models?
Reply #14November 19, 2010, 10:16:00 pm
79rabbit4dr
« Reply #14 on: November 19, 2010, 10:16:00 pm »
I just remember my Engine Performance prof mentioning it... quick google search produced this handy little list though;
http://www.obdii.com/connector.html
