Author Topic: How do you remove a MKII dipstick?  (Read 7667 times)
October 24, 2010, 02:44:44 pm
mtnbob
  • 738
« on: October 24, 2010, 02:44:44 pm »
Trying to strip my block down before I take it to the machine shop, and I can't figure out how to remove the dipstick. I thought they were just pressed in, with a gasket keeping it from leaking, but this one is being stubborn. Is their a way to do it without resorting to brute force ::)
Thanks
Robert
96 Subaru Outback Wagon
Reply #1October 24, 2010, 02:54:33 pm
rallydiesel
  • 1880
Re: How do you remove a MKII dipstick?
« Reply #1 on: October 24, 2010, 02:54:33 pm »
It is pressed in. Just put a block of wood on the end and tap it out with a hammer.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 24, 2010, 10:12:45 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: October 24, 2010, 10:12:45 pm »
Mine is bolted to the bottom of the injection bump but otherwise the same. Pull really really hard on it and it will come out.
Reply #3October 25, 2010, 03:26:32 pm
mtnbob
  • 738
« Reply #3 on: October 25, 2010, 03:26:32 pm »
That is how my past ones have been, for some reason this one seems to be in pretty tight :o
Reply #4October 25, 2010, 03:49:03 pm
rallydiesel
  • 1880
« Reply #4 on: October 25, 2010, 03:49:03 pm »
Maybe the previous owner thought JB weld would make a good sealant  :-[.
Reply #5October 25, 2010, 11:11:39 pm
mtnbob
  • 738
« Reply #5 on: October 25, 2010, 11:11:39 pm »
My thoughts exactly :o
Reply #6October 26, 2010, 06:56:31 am
« Reply #6 on: October 26, 2010, 06:56:31 am »
im thinking hes been talking about the tube the whole time..
Reply #7October 26, 2010, 04:26:10 pm
mtnbob
  • 738
« Reply #7 on: October 26, 2010, 04:26:10 pm »
Yes LOL the dipstick tube! Sorry for the error. ;D
Reply #8October 27, 2010, 01:04:25 am
  • 3468
« Reply #8 on: October 27, 2010, 01:04:25 am »
I knew what you meant :P
Reply #9October 27, 2010, 04:11:26 am
« Reply #9 on: October 27, 2010, 04:11:26 am »
Mine was in pretty good. It seemed I had to pull and almost straighten it the first little bit and then twist to get it out. Mine doesn't leak around the base though so I think it is a good thing.
Reply #10October 27, 2010, 01:15:30 pm
truckinwagen
  • 1895
« Reply #10 on: October 27, 2010, 01:15:30 pm »
I used a drift from inside the block to push it out.
-Owen
83 Opel Kadett Diesel
Reply #11December 07, 2010, 09:53:07 pm
RajendirSharma
  • 8
« Reply #11 on: December 07, 2010, 09:53:07 pm »
I used a washer that fitted the bore of the dipstick tube from underneath (from the oil pan side) and pushed it up by hammering via a wooden stick.  It is very difficult to get a dip stick tube.  I have a new one that costed about $70.  No junk yard had one.  I have three of those tubes now; short one (block with 11mm headbolt), gas engine one, and a new one for 1985 block that accept 12mm bolt.   Let me know if you wish to buy any of those.  Send me an e-mail at [email protected].
Reply #12December 08, 2010, 10:08:15 am
« Reply #12 on: December 08, 2010, 10:08:15 am »
I've made custom dipstick tubes from appropriately sized steel brake line.
Me too!
my 1.5 kept blowing the stock dip stick out of the block.. so i used a chunk of brake line, and like you, made my own. but i made it so that the dip stick actually threads onto the end of the tube..
