Author Topic: VW MK1 engine mounts with noise isolators (heavy duty )  (Read 5331 times)
October 23, 2010, 08:06:59 am
GEE-BEE
  • 1604
« on: October 23, 2010, 08:06:59 am »
There Done
ebay item # 270632970130
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1October 23, 2010, 12:27:53 pm
Re: VW MK1 engine mounts with noise isolators (heavy duty )
« Reply #1 on: October 23, 2010, 12:27:53 pm »
That's weird I didn't know those did anything. I threw them out years ago after seeing what a pain it was to put 'em in. ::)
Reply #2October 25, 2010, 07:04:20 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #2 on: October 25, 2010, 07:04:20 am »
GEE-BEE
have you tried these? If so what's your opinion of them
Reply #3October 25, 2010, 08:17:59 am
GEE-BEE
  • 1604
« Reply #3 on: October 25, 2010, 08:17:59 am »
I will installing the isolator's this week
I figured for the price of new mount's why not, these were added on the 1983 and later model's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #4October 25, 2010, 05:18:52 pm
ventureforth
  • 164
« Reply #4 on: October 25, 2010, 05:18:52 pm »
I found a set at a junk yard (of the isolators) off a Cabby.  I was looking for the mount brackets to press in new mounts without having to remove mine from my DD.  My Rabbit didn't have any isolators, so I was curious.  I installed them just to see.  Was kind of a PITA to install but it did make a considerable difference.  Got rid of a lot off rattle and hum.  And those were used yard finds on used mounts.  I'm sure GEE-BEE's would work even better, especially in combination with new mounts.  Just my $.02
Reply #5October 25, 2010, 05:40:04 pm
GEE-BEE
  • 1604
« Reply #5 on: October 25, 2010, 05:40:04 pm »
Just the Buffers here :
Ebay item :360298858163
Giles Pump OHC
MK1 JETTA DASH
