General Information
Upgrades (non engine related )
VW MK1 engine mounts with noise isolators (heavy duty )
Topic: VW MK1 engine mounts with noise isolators (heavy duty ) (Read 5450 times)
October 23, 2010, 08:06:59 am
GEE-BEE
October 23, 2010, 08:06:59 am »
There Done
ebay item # 270632970130
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
October 23, 2010, 12:27:53 pm
rabbitman
Re: VW MK1 engine mounts with noise isolators (heavy duty )
October 23, 2010, 12:27:53 pm »
That's weird I didn't know those did anything. I threw them out years ago after seeing what a pain it was to put 'em in.
October 25, 2010, 07:04:20 am
BlastIt
October 25, 2010, 07:04:20 am »
GEE-BEE
have you tried these? If so what's your opinion of them
October 25, 2010, 08:17:59 am
GEE-BEE
October 25, 2010, 08:17:59 am »
I will installing the isolator's this week
I figured for the price of new mount's why not, these were added on the 1983 and later model's
GB
Giles Pump OHC
MK1 JETTA DASH
October 25, 2010, 05:18:52 pm
ventureforth
October 25, 2010, 05:18:52 pm »
I found a set at a junk yard (of the isolators) off a Cabby. I was looking for the mount brackets to press in new mounts without having to remove mine from my DD. My Rabbit didn't have any isolators, so I was curious. I installed them just to see. Was kind of a PITA to install but it did make a considerable difference. Got rid of a lot off rattle and hum. And those were used yard finds on used mounts. I'm sure GEE-BEE's would work even better, especially in combination with new mounts. Just my $.02
October 25, 2010, 05:40:04 pm
GEE-BEE
October 25, 2010, 05:40:04 pm »
Just the Buffers here :
Ebay item :360298858163
Giles Pump OHC
MK1 JETTA DASH
General Information
