Author Topic: Bottom end reassembly  (Read 2427 times)
October 06, 2010, 07:10:22 pm
« on: October 06, 2010, 07:10:22 pm »
Hoping to beging putting the TD back together soon so a question seperate from the build thread.
This will be my first real rebuild, so any tips or tricks appreciated. Have assembly lube!
I opted for ARP hardware for mains, rods, and head bolts. I recall seeing posts about different torque specs for the ARP head bolts when using the ARP supplied lube. Do I need to do anything special on any of these three areas or just stick to the Bentley?
Thanks,
Bill
Reply #1October 06, 2010, 07:47:20 pm
Re: Bottom end reassembly
« Reply #1 on: October 06, 2010, 07:47:20 pm »
Stick with what ARP tells you.
Except the head bolts. If you have the VW new ones I have no clue. The Cogsworth old ones that everyone is using before. Here is a thread that I will link that has "zukgod1 head torquing procedure" I went to 105lbs with my head bolts. I have an MLS 1.9L HG and wanted to make sure it was crushed good.
I turned my block heater on 2 times and let cool each time before torquing. Took a couple days, but I don't have any issues in 800 plus miles.
http://www.vwdiesel.net/forum/index.php?topic=21182.15   about mid page you'll see zuk's procedure. I did it very similar, but instead of running the engine I used a block heater so no combustion forces were on the HG :D
« Last Edit: October 06, 2010, 09:00:55 pm by theman53 »
Reply #2October 07, 2010, 02:29:21 am
VW Smokr
  • 114
« Reply #2 on: October 07, 2010, 02:29:21 am »
... I did it very similar, but instead of running the engine I used a block heater so no combustion forces were on the HG :D
Now that makes sense! Thanks.
J.R.
SoCal
Reply #3October 07, 2010, 05:59:24 am
« Reply #3 on: October 07, 2010, 05:59:24 am »
I have the new ARP VW Diesel bolts. I guess not a lot of real world experience on them yet?
Was going to swap to the TDI timing sprocket, but my machinist did not think it a wise choice to modify the end of the crank, and starting to loose serious amounts of free time to work, so I will be going with a new 1.6TD sprocket. Sticking with a v-belt arrangement so I imagine this will be fine.
Good idea about using the block heater to heat cycle the thing. I will be installing a new block heater as well.
Reply #4October 07, 2010, 08:30:45 am
« Reply #4 on: October 07, 2010, 08:30:45 am »
The TDi crank sprocket is never a bad idea, but its prully not that necessary on a 1.6TD.. the AAZ and tdi engines are the ones that got the crank wobble..
Reply #5October 07, 2010, 08:43:35 am
gnavs
  • 340
« Reply #5 on: October 07, 2010, 08:43:35 am »
Agreed, you should be fine on a 1.6, but there's also no danger in machining your crank nose to fit a new pulley.
