S-PAutomotive.com
Author Topic: EGR Deleting?  (Read 48126 times)
Reply #15December 17, 2010, 09:49:50 pm
Re: EGR Deleting?
« Reply #15 on: December 17, 2010, 09:49:50 pm »
In general there's no winning reason to delete the EGR anymore, in the era of ULSD which leaves no oily residue to speak of.
As well, the ECU will throw a permanent CEL, the engine will take slightly longer to warm up (since the system is water-cooled)  and fuel economy is reported to get slightly worse.
If it's not leaking most people leave 'em be these days, particularly in any district with physical emission inspections.
« Last Edit: December 17, 2010, 10:04:48 pm by Vincent Waldon »
Reply #16December 18, 2010, 12:05:23 am
RadoTD
  • 513
    Stage WTF
Re: EGR Deleting?
« Reply #16 on: December 18, 2010, 12:05:23 am »
OK, then an EGR delete is not the droid you're looking for.   ;)
[pause thread]
I think Vincent just made a Star Wars joke!
[/pause thread]
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #17December 18, 2010, 12:11:11 am
Re: EGR Deleting?
« Reply #17 on: December 18, 2010, 12:11:11 am »
Jebus.... took you guys long enough....  ;)
On the other hand, most of you guys are probably too young to remember the *real* Star Wars.  ;D
Reply #18December 18, 2010, 12:37:17 am
Re: EGR Deleting?
« Reply #18 on: December 18, 2010, 12:37:17 am »
I have seen all 6 ep. ;) Guy was a genius.
Reply #19December 20, 2010, 04:51:57 pm
Re: EGR Deleting?
« Reply #19 on: December 20, 2010, 04:51:57 pm »
Dont forget about Kerma TDI.
Charlie will do about any tune you want, including EGR Delete.
Getting mine done in a week I think.
Reply #20January 28, 2011, 11:52:14 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: EGR Deleting?
« Reply #20 on: January 28, 2011, 11:52:14 pm »
Effff Kerma... Not a person i buy from.
But you can reduce the EGR rate by vcds-
Channel 3: EGR
-To decrease the EGR rate, increase the number to the highest possible value (typically 33768).
-This will prevent/slow down the intake manifold clogging problem and reduce smoke.
-Though the MAF at idle is still within specifications (370 mg/h) do not use this adaptation on the road :-)
-Again, this EGR setting is for off-road use only !!!
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
