Author Topic: Would 1.6 intake work on 1.9 head if ground right?  (Read 2364 times)
September 24, 2010, 08:27:53 pm
kevinm
  • 78
« on: September 24, 2010, 08:27:53 pm »
Can you grind the ports into the 'D' shape to make it work.  Reason i ask is i picked up the 1.6 Passenger Custom intake of a fellow board member and dont really want to keep my head as its all cracked in all 4 of the precups and then some....
Reply #1September 25, 2010, 06:56:37 am
  • 1739
Re: Would 1.6 intake work on 1.9 head if ground right?
« Reply #1 on: September 25, 2010, 06:56:37 am »
Depends if there is enough meat around the port. I needed to weld out and JB weld [that was more for esthetics] and then ground the shape following the new "d" shape gasket
Reply #2September 25, 2010, 08:09:45 am
« Reply #2 on: September 25, 2010, 08:09:45 am »
if you are replacing the head, why not just replace it with the right head?
does the AAZ intake ports really make that much of a difference? even with a choked up 1.6 manifold? surely the ports in the 1.9 manifold are bigger..
Reply #3September 25, 2010, 08:25:35 am
kevinm
  • 78
« Reply #3 on: September 25, 2010, 08:25:35 am »
the intake manifold is custom a custom welded ceramic coated Passenger Performance item...  And its got the 1.6 ports on it.. could someone take a vernier and tell me how tall the "D" port is and wide would be nice too...  Thanks.  If i can grind it ill get a 1.9 head.
Reply #4September 25, 2010, 08:38:14 am
« Reply #4 on: September 25, 2010, 08:38:14 am »
im aware its a ***in 1.6 mani, not a stock one. but a 1.9 mani still must flow more. it has bigger ports.. a D has more surface area than an O
