Author Topic: IP fuel leak  (Read 4385 times)
September 03, 2010, 12:29:23 pm
4wheeler
IP fuel leak
« on: September 03, 2010, 12:29:23 pm »
Damn thing is leaking from the boost pin inside the LDA and filling up the cavity where the boost control pin is housed. In turn leaking out the vent.
Looks as if I can pull out a plug on the side of the LDA housing and see the little pin.
Is there a seal in there I`m guessing?
How would I go about fixing this leak.  Looking for both a quick fix without having to pull the top off and a the proper fix for when the long weekend is over..
Any ideas???
Reply #1September 03, 2010, 12:30:22 pm
Re: IP fuel leak
« Reply #1 on: September 03, 2010, 12:30:22 pm »
You're in luck... the FAQ points to a thread that covers off on this one nicely.
Reply #2September 03, 2010, 01:18:13 pm
Re: IP fuel leak
« Reply #2 on: September 03, 2010, 01:18:13 pm »
There isn't really a quick fix... unless you remove the vent and put in a pipe plug or something.
Reply #3September 03, 2010, 02:30:45 pm
Re: IP fuel leak
« Reply #3 on: September 03, 2010, 02:30:45 pm »
True dat... the internal pump pressure can be over 100psi, so if it wants to leak its gonna!
Reply #4September 03, 2010, 05:02:18 pm
4wheeler
Re: IP fuel leak
« Reply #4 on: September 03, 2010, 05:02:18 pm »
well I guess the LDA is usless untill I fix the damn thing... suppose I`ll have to tur up the fuel screw for the weekend...
Reply #5September 11, 2012, 12:50:54 am
vako
  • 187
Re: IP fuel leak
« Reply #5 on: September 11, 2012, 12:50:54 am »
will the pipe plug work? i really dont have any time for disassembling the pump now. if it will not tear the diaphragm of the lda I would plug the vent for few weeks and then reseal the whole pump
Reply #6September 11, 2012, 07:21:27 am
Reply #7September 11, 2012, 06:16:22 pm
Re: IP fuel leak
« Reply #7 on: September 11, 2012, 06:16:22 pm »
The cummins kit is the wrong sized shaft so you'll need to get a different driveshaft seal, and I don't know what size shaft the other one is. It looks like they are both missing the o-ring for the shut off lever on the LDA.
Reply #8December 09, 2012, 11:30:09 pm
vako
  • 187
Re: IP fuel leak
« Reply #8 on: December 09, 2012, 11:30:09 pm »
http://www.ebay.com/itm/GASKET-KIT-SEAL-KIT-VW-VOLKSWAGEN-VE-Injection-Pump-Diesel-/130814603675?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7528719b&vxp=mtr
i'm planning on purchasing this kit today or tomorrow. could you tell me if it will fit my 1.9TD aaz  ;D
cheers  ???
Reply #9December 10, 2012, 01:44:07 pm
Re: IP fuel leak
« Reply #9 on: December 10, 2012, 01:44:07 pm »
Says so right in the description ;)
Quote from: Gasket Pros!
NEW IN THE BOX OEM BOSCH GASKET AND SEAL KIT FOR VE INJECTION PUMPS  FOR VW DIESELS
FITS 4 CYLINDER VW DIESELS  1.6 and 1.9  ( NOT TDI APPLICATIONS )
ALL SEALS AND ORINGS ARE VITON AND LOW SULFUR APPROVED
 INCLUDES 17MM DRIVESHAFT SEAL
Reply #10December 10, 2012, 02:05:45 pm
vako
  • 187
Re: IP fuel leak
« Reply #10 on: December 10, 2012, 02:05:45 pm »
i was hesitating if it includes seals for lda(that is my problem at the reall moment). and the seller does not have info about that. i also think that it should be the right choice for me ;D
this is  another alternative http://www.ebay.co.uk/itm/BOSCH-VE-Turbodiesel-INJECTION-PUMP-SEAL-KIT-/271110826945?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1f76ebc1&_uhb=1
but here i cant see the shaft seal and the seller has not answered yet :)))
