Author Topic: Wtb: CLUSTER W/ TACH CE2  (Read 3841 times)
August 28, 2010, 06:32:22 pm
KinseyJ
  • 11
« on: August 28, 2010, 06:32:22 pm »
someone has to have one out there willing to let it go for 100 bucks.
91' jetta 1.6TD, G60 intake manifold, GTD injectors, FMIC, custom downpipe, 2.5" straitpipe exhaust, oversized pistons, fresh rebuild, running 10 psi. finally done!! 9 gruelling months of late nights in the garage.
Reply #1August 28, 2010, 07:16:06 pm
dieselherb1
  • 354
Re: Wtb: CLUSTER W/ TACH CE2
« Reply #1 on: August 28, 2010, 07:16:06 pm »
I think I have what you want. What do you need, what plug-s would it have on it?
Reply #2August 29, 2010, 12:30:10 pm
Baron VonZeppelin
« Reply #2 on: August 29, 2010, 12:30:10 pm »
Herb, CE1 has an upshift indicator.
CE2 does not.
if that helps.
And of course, Diesel unit will have a Gplug indicator, and not say UnLeaded Fuel anywhere. lol  ;)
Reply #3August 30, 2010, 06:09:13 am
shortysclimbin
  • 138
    • Performance Diesel Engineering
« Reply #3 on: August 30, 2010, 06:09:13 am »
I mmay have one kicking around Ce2 has two plugs ce1 has one correct?
Reply #4August 30, 2010, 06:23:28 pm
Ziptar
  • 565
« Reply #4 on: August 30, 2010, 06:23:28 pm »
Other way around, CE2 has one plug, CE1 has two plugs a black one and a white one. The switch from CE1 to CE2 was halfway through 1989.
1985 thru 1989.5 = CE1 - 2 plugs
From 1989.5-1992 = CE2 - 1 plug
You can also tell by the location of the fuel gauge,  CE1 has it in the tach face, CE2 it's top center of the cluster. CE2 clusters also have an LED for Temperature and the glow plug LED gets moved to the second row.
CE1 Cluster
CE2 Cluster
Credit to Op-Ivy for the pictures  ;)
