Hi!
I've got a 91 1,6 ECODiesel , and want to change the turbo from k14 to k24.
The engine has the following Modifications:
Stock GTD intercooler, LDA Inj. Pump, governor mod, 10mm Plunger, 2,5" Downpipe and exhaust without Cat. , 30psi boost, Fuel turned up to get a light haze.
AAZ head gasket, 12.9 grade head bolts, head and manifolds light ported.
Now, i've got a Garret gt1852V from a Mercedes Sprinter van, 2.2 cdi and thought about putting it on my eco, because the k24 and still need more power...
I know that i need a control for the vnt turbo , but it should not be the problem to build one with the informations on this forum.
Has anyone ever put a gt1852v on a 1.6 before? Will it increase the power a lot? are there some flow maps for it? how much boost will it make? and how much power can i expect?
my main goal is not the faster spool of the vnts, i just want it to pull harder ^^
my k24 spools at a bit over 2100 rpm, what is ok for me, but i think with a proper control, the gt1852v should also spool faster/produce more low end boost as the old k24.
Thanks
