Turbo converted polo 1.4d(n/a) (1W) with video´s
4
5
9
Topic: Turbo converted polo 1.4d(n/a) (1W) with video´s (Read 65110 times)
August 16, 2010, 01:33:13 pm
polo_td
August 16, 2010, 01:33:13 pm »
Hi just want to show you my ride.
Its a 93 polo "stielheck".
Click the links for more info and videos.
There´s been some more updates after this i.e intercooler etc.
please comments really needed to boost my building and to get some new ideas..
build info:
http://z8.invisionfree.com/POLO3/index.php?s=6e0d428558703f87f42908f122370b84&showtopic=7338&st=0
Some vid´s:
My Black stielheck Polo td 0-100km/h 86c
polo td
polo td acc 0-100 4fun
Last Edit: August 16, 2010, 02:20:16 pm by polo_td
August 16, 2010, 03:11:38 pm
Re: Turbo converted polo 1.4d(n/a) (1W) with video´s
August 16, 2010, 03:11:38 pm »
woah i didn't realize there was actually a small block diesel other than the later direct injection stuff. thats awesome, any pictures of the head off? also this engine is cross flow right?
August 16, 2010, 03:13:14 pm
August 16, 2010, 03:13:14 pm »
me want
August 16, 2010, 09:55:20 pm
polo_td
August 16, 2010, 09:55:20 pm »
Hi.
Yes there is a small block diesel, but no i dont have any pics with the top of.
I have a extra head and i can take some pics on that one if its interesting?
thomas
August 17, 2010, 11:19:20 am
polo_td
August 17, 2010, 11:19:20 am »
Hi all, just want to show you how this car was before conversion.
This i not my car but exactly the same otherwise.
Its 48bhp std........
August 18, 2010, 01:45:14 pm
August 18, 2010, 01:45:14 pm »
yeah id love to see the spare head
August 18, 2010, 09:49:03 pm
polo_td
August 18, 2010, 09:49:03 pm »
Ok, pics later today?
thomas
August 21, 2010, 08:23:32 am
polo_td
August 21, 2010, 08:23:32 am »
Hi again.
Noticed that i missed the link to the video showing the car before i converted it to a turbo.
polo 1.4 D sprint
Pics of the head is on it´s way, will upload these later today.
August 30, 2010, 09:52:10 pm
polo_td
August 30, 2010, 09:52:10 pm »
Here´s some pics of the spare head as promised.
And here is a pic of the block.
August 30, 2010, 10:58:27 pm
August 30, 2010, 10:58:27 pm »
looks like that thing would flow LOADS better than a US spec diesel head..
September 02, 2010, 09:18:25 pm
polo_td
September 02, 2010, 09:18:25 pm »
Hi.
This is how its lookslike now.
2010 edition.
Thomas
Sweden
Reply #11
September 03, 2010, 05:49:13 am
gldgti
Reply #11 on:
September 03, 2010, 05:49:13 am »
Great car! Not many "breadvan" polo's around, thats for sure. good job.
The cross flow head is indeed an interesting one eh? but, VW seemed happy to use counterflow for so long, it can't be so bad.
'91 Golf Cabrio 1.9TD
Reply #12
January 30, 2011, 08:27:18 am
Reply #12 on:
January 30, 2011, 08:27:18 am »
i just wanna bump this cause it was cool
Reply #13
February 07, 2011, 12:24:58 am
polo_td
Reply #13 on:
February 07, 2011, 12:24:58 am »
Hi again.
Started with the car project again.
This time i will rebuild the pump ith LDA.
The car exterior will be wider due to rear axel mods.
Something like this, Polo rallye style!!!
Interior will be updated aswell.
Brakes are done, 256mm ventilated disc.
Rear disc convertion, Masterbrakecylinder uppgraded to 23mm instead of 20mm. Braided hoses all around Hoses and pads haven´t arrived yet thou.
A bit messy to get the handbrake wires to work, i did a sleeve to be able to keep the original wires.
Rear camber angle adjusted to -2 degree.
Intecooler from BMW 525tds and turbo from the same car and a new manifold will be done.
Oilcooler and sandwich plate from Volvo Group-A with internal termostat is already mounted.
Clutch and pressure plate upgraded to a high spec. version (200bhp, 280Nm)
200mm instead of 180mm as std.
thomas
The Black steilheck
Sweden
Reply #14
February 07, 2011, 01:57:31 pm
Reply #14 on:
February 07, 2011, 01:57:31 pm »
i would say these heads probably don't flow better than a 1.6td head, although they are cross flow, cross flow is not really better in terms of flow, just better for heat and that is negligible. aba heads hardly flow better than 8v counter flow heads with similar sized valves. but i would say judging by how close the port is to the deck, both ports make a very hard 90 degree turn into the chamber hurting flow, and also even tho that head is cross flow the intake ports are right next to the prechamber where there is ALOT of heat. cool engine regardless, i just doubt it flows any better
4
5
9
